10-05-2021, 08:34 PM | #1 |
Rep 2,224
Center Armrest Installation Help
I am wrapping up an interior swap on my vert from black to fox red and could use some guidance on the center armrest install. Unfortunately I didn't pay close enough attention to how this spring was "loaded" before uninstalling the old one and now I am unsure how to properly install. So far I am pretty sure I need to get the spring on the armrest "legs" in the little grooves and then insert into the center console and install the silver set pins (I know they are not fully seated yet), but then how do I load the spring? I saw a video on ECS Tuning where they push the center part of the spring behind a notch in the center area, but I know for a fact that is not how my previous one was installed as the spring is not bent at all and that would require a significant bend. It would also require significant effort and I can't seem to get that to work. Can anyone provide some guidance? ECS video also shows a small gear that my previous armrest did not have, nor does the replacement.
Bake
2011 Alpine White on Black 535i M-Sport 2013 Space Gray on Fox Red M3 Vert |
10-06-2021, 12:02 AM | #2 |
Rep 2,747
You got to push it into place with a big flat blade. It's easier to do with the lid up.. (no load on the spring)
Edit: so with the hinge pin in place through the spring in the right orientation, put the console lid in the up position and push the spring in to place with a large flat blade. Looks right in the top pic, open and follow above instruction.
9ers
10-06-2021, 09:13 AM | #3 |
Rep 684
First you need to remove all the Fox red interior pieces put em in a crate and ship them to me. In return I'll send you all my black interior parts.
Sorry I can't help. I'm looking to do the swap as well but can't find seats that are in the same condition as mine. |
10-06-2021, 12:43 PM | #4 | ||
Rep 2,224
Bake
LakeSurfer823.50 |
