06-04-2020, 12:56 PM | #1 |
Rep 1,055
Core4 Motorsports M14 90MM press studs into new hubs
Hello, I am selling a pair of brand new front axle *F*A*G hubs for the E9x M3 with pressed MSI M14 90mm length studs. MSI manufactures studs for various pro teams. These studs are pressed into the hub as opposed to threaded on which is typically found with other stud options. This results in greater strength for decreased probability of breaking the studs. The M14 stud is also thicker than the oem stud on the E9x M3, again for added strength, and you may need to drill your rotor hats for these to pass through, please be sure to measure first. More information can be found on Core4s page here: https://www.core4motorsports.com/pro...onversion-hubs The reason I am not able to use them is because I need longer studs for the set-up I am looking to run and currently having longer studs custom made. I am only looking to recoup my cost here to be used toward the new set. Price is net of fees.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
06-04-2020, 01:27 PM | #2 |
Rep 3,408
These are awesome! I have the m12 version. Super easy install too (4 bolts).
Would you mind sharing the wheel setup that requires > 90mm length?
mobilenemo22.00 |
06-04-2020, 01:46 PM | #3 |
Rep 1,055
I'm trying to fit the M4 GT4 wheels, they have a thick pad and require a spacer to clear the strut due to being 18x11 et30, I need longer studs to be sure I can still have adequate thread engagement. @slicer has done preliminary fitting but I wanted to see if my experience would be the same with these studs.
From measurements these will cut it really close and I'd rather not install and it not work. IMO, a 12mm spacer is the biggest that will safely allow for sufficient thread engagement with this wheel and its possible I may need a 15mm. I like the added safety of these pressed and thicker studs so am pursuing the same option for the replacements.
DRLane3988.50 |
06-05-2020, 08:02 AM | #6 |
Rep 1,055
06-07-2020, 10:29 AM | #8 |
Alex - IG @screamer
601
Rep 472
Are these for the Front or Rear?
Instagram: @screamer
- 2013 Subaru STi Hatch - White - Racecar - 2011 BMW E92 M3 - Moonstone - Collector Car - 2008 BMW E90 M3 - Silverstone - Racecar |
06-07-2020, 02:37 PM | #9 |
Rep 1,055
reidetailing600.50 |
08-30-2020, 08:31 PM | #12 |
Rep 3,456
Drives: Harrop E90 M3
From an M4 GT4. They run a large spacer with no issues. These are top quality studs! GLWS
08-31-2020, 02:22 PM | #13 |
Rep 1,055
01-08-2021, 03:23 PM | #14 |
Rep 859
