11-01-2015, 06:40 PM | #1 |
Rep 55
ZHP Knob OEM Install
Since the OEM M3 6 speed shift knob is illuminated, is it okay to install the non illuminated ZHP one?
https://www.ecstuning.com/Search/Zhp/ES47397/ Will I get any fault codes? Thanks, Andy |
11-01-2015, 10:51 PM | #4 | |
Rep 168
Here's mine, along with a tri-color shift boot from redlinegoods.com.
2006 Cayman S
2011 E92 M3 Comp Pkg |
11-02-2015, 07:20 AM | #9 |
Rep 1,320
I did the swap to the F10 knob and can confirm that it is indeed illuminated, weighted, and the leather on the knob and boot is different than the E9X's leather. The difference in leather is negligible when compared to the difference in feel of the knob. So I'd say go for the F10.
11-02-2015, 08:24 AM | #11 |
Rep 40
I did the ZHP install and retrofit for illuminated insert myself. Followed a DIY and made a mistake knicking a corner of the leather while dremelling . Had to order another one, start again, but eventually everything worked out great second time around. Did take time and patience with Dremel and drilling.
Seems like F10 shift knob is the much easier route. leatherZ has a comparison of ZHP vs M5 shift knob and the weights are quite similar with identical dimensions. Others you would order the F10 M5 knob from you would have to remove the boot yourself to put the M3 on, or just remove the base, but have to fiddle around with making the e92 base work on it. Http://leatherz.com/Merchant5/mercha...egory_Code=NEW I ended up cutting my original shift boot and connecting to the ZHP knob I using the oem base with perfect fit. Good luck. Last edited by nobodyhere; 11-02-2015 at 08:30 AM.. |
11-02-2015, 08:44 AM | #12 | |
Rep 1,320
http://www.getbmwparts.com/partlocat...catalogid=4462 It comes attached to the boot, but to the F10 ring (which is of a different shape). Thus, I cut the original boot and used the zip-tie method. |
11-02-2015, 10:26 AM | #13 | ||
Rep 55
11-02-2015, 10:33 AM | #14 |
Rep 1,566
That looks perfect. If anybody is debating using the F10 shift boot vs the E92 shift boot, I recommend leaving the F10 boot that comes with the knob on there. You will not get the area under the silver ring looking as clean as the pic above if you choose to cut off the F10 boot and zip tie the knob to the E92 boot.
11-02-2015, 10:55 AM | #15 | |
Rep 1,320
1) Cut the F10 knob from its boot and affix onto the E9X's stock boot and ring (Zip-Tie) 2) Cut the F10 knob + boot combo from it's pentagonal shaped ring, cut E9X knob + boot from it's ring, swap the F10 assembly onto the E9X's ring and replace. (some glue the F10 knob + boot to the E9X ring, and others cut holes for the base ring to attach properly....your choice.) |
11-02-2015, 11:22 AM | #16 | ||
Rep 55
11-02-2015, 11:30 AM | #17 |
Rep 10,614
I think the lighted knob looks cool, but I agree it is necessary only for those who do not know where the gears are. If multiple drive your car and some are used to 5 speeds, they might not even know there is a 6th gear at night unless the 6 is lit up.
11-02-2015, 02:21 PM | #18 |
Rep 2,513
Took me 30-45 mins max.
AW|FR 6MT E92 ///M3 |
11-02-2015, 02:37 PM | #19 |
Rep 1,923
I dont remember when was the last time I saw that my knob was illuminated lol
11-03-2015, 04:09 AM | #22 |
Rep 101
Personally I think the illuminated shift knob is completely pointless and just adds to all the orange light pollution inside the cabin. Happy to now have a non-illuminated knob with the ZHP, plus the height and weight of the shifter are much more comfortable than OEM. The only real benefit the F10 M5 knob has is the built in illumination.
