05-10-2018, 10:28 AM | #1 |
Rep 765
Oil Consumption city vs. highway
I am trying to figure out if I have a problem or not.
I bought my car at 17k miles and drove it across the entire United States (oregon > virginia) ~3500 miles with some scenery in colorado. The oil was about 1/2 when I started and then popped to 1/4 when I arrived. So at that rate, it's like 1 quart of oil consumed say per 12000 miles. Then had oil changed and the doofuses at the shop did the classic overfill of 9 quarts. I drove on that for about 20 miles thinking it was the finicky oil gauge and would "settle", and then realizing there was an issue just drained to the appropriate level myself. I've then added another 3000 miles and have gone from full to 1/4 quart empty. Most of this has been city driving. So say 1 quart per 4000 miles. Is the variation between highway and city in your all experience normal, or did the doofuses at the shop reward me with an early christmas present of oil thirst on a low mileage vehicle? If such is the new life, anything I should be on the lookout for other than having a quart of oil in the backseat to refill here and there. Thanks. |
05-10-2018, 10:46 AM | #2 |
Rep 1,930
Our cars do drink oil on long highway drives cruising 60-75 mph. If you also WOT a lot it drinks more. On city driving I burn zero oil.
Got a oil change right after I picked up my car in Houston and driving to NY, I ended up in the half mark. Typically on my 5K OCI I put in a quart of oil. |
05-10-2018, 11:54 AM | #3 | |
Rep 3,964
Dave
05-10-2018, 11:57 AM | #4 | |
Rep 50
13 M3 Coupe Stripper 6MT Space Gray / Black / Carbon - Dinan intake, pulley, springs, toe links, monoballs, strut braces, ride and handling kit with Bilstein B8's, MPE V2, MP Carbon Spoiler, UCP, Autosolutions SSK, Turner Solid Subframe bushings, Goodridge ss lines
05-10-2018, 01:45 PM | #5 |
Rep 765
Thanks all. My experience seems to be the opposite. Very low fuel consumption highway driving. Overfill on oil change. Sudden higher fuel consumption in mostly city driving.
However I will continue to monitor. If it's 4-5k needing one quart seems that's what I have and no reason for concern. |
05-10-2018, 02:01 PM | #7 |
Rep 2,359
S65 has surprisingly good highway fuel economy as long as you are sensible with the throttle. Then again it doesn't compare to 4 bangers or turbos at legal speeds...
Pass me if you can.
05-10-2018, 03:30 PM | #8 |
Rep 765
05-10-2018, 05:42 PM | #11 |
Stop the hate, get a V8
3850
Rep 8,625
The quantity is largely irrelevant as long as it isn't something ridiculous like a quart every 1000 miles. Some cars consume oil, some do not. This is just normal engine variation.
What you want is a consistent rate of consumption. Increases or decreases point to something else going on. FWIW, highway miles are generally easy on the car since you have steady RPM, low load, constant airflow, smooth surface, minimal transmission shifting, minimal steering, etc. City miles are much harder on the car. This is why low mileage vehicles worry me.
Past: 2011.5 M3 sedan ZCP |
05-10-2018, 06:17 PM | #12 |
Rep 1,216
My car almost always shows 1/2 full after driving on the highway for a bit. Once I get off the highway it goes back up. Don't know the reasoning but its never more than slightly less than full the rest of the time.
2011.5 E90 M3
LeMans Blue |
05-10-2018, 06:50 PM | #13 |
Rep 765
05-11-2018, 08:44 AM | #14 | |
3850
Rep 8,625
If oil consumption starts to rise, there are typically other secondary symptoms.
m3jala543.50 |
05-11-2018, 09:03 AM | #15 | ||
Rep 765
05-26-2018, 09:05 AM | #16 | |
Rep 40
The rings designed to looser tolerances for heat at high revs and a lot of fuel gets into the oil. Designed this way. When you run the car to operating temps long highway drives it burns some of that off so often shows needing oil top up. |
