04-08-2018, 10:27 PM | #1 |
Rep 769
Am i waiting too long for an oil change?
Hey everyone,
I am just being a little OCD here and need a quick opinion. I am changing my rod bearings on May 18th with Deansbimmer, however my last oil change was done on May 17th of 2017. Since then i drove almost 6k miles. It will be 300 mile trip to go see Deansbimmer and i will probably drive another 500 before the trip(probably less actually). Do you guys think i should just go ahead and change oil now or push the car until i change bearings? The car is approaching 80k miles at this point. |
04-08-2018, 10:34 PM | #2 |
Rep 12,711
you will be just fine.
i did a 1,400 road trip and three track days immediately after doing rod bearings before my first oil change.
TrAcK TRaP412.50 |
04-08-2018, 10:47 PM | #3 |
Rep 769
04-08-2018, 11:45 PM | #4 |
Rep 12,711
bmw says 15k or one year, so you're close. i personally wouldn't worry about it if you aren't going to be beating on it- only because you are about to do bearings and get fresh oil.
04-09-2018, 05:32 PM | #5 |
Stop the hate, get a V8
3848
Rep 8,625
I'd leave the oil in there for now. Change it out sometime after you get those bearings replaced.
Past: 2011.5 M3 sedan ZCP |
04-10-2018, 02:36 PM | #6 | |
Rep 7,054
Well done OP, you clearly look after your S65. Touching 7k for a change can't possibly be anything your baby will notice. |
04-10-2018, 02:56 PM | #8 |
Rep 3,972
1 year and even 8k miles is nothing to worry about on an oil change before a rod bearing job I'd say.
Don't sweat it.
04-10-2018, 03:51 PM | #10 | |
3848
Rep 8,625
It's 24,000km/15,000mi OR 2 years, whichever comes first. However, there is the low-usage change interval (specified in a TSB) which says if you're not driving the car regularly, change it once a year regardless of mileage. This would apply to anyone who isn't DD'ing it, I'd say.
04-10-2018, 04:53 PM | #11 | ||
Rep 769
04-10-2018, 04:56 PM | #12 |
Rep 1,003
Drives: 2008 E90 M3 DCT Silverstone II
Nothing will prolly happen to most these cars with extending it out much further then what your timeframe is.
Some of us are neurotic (myself included) changing our oil every 5k miles (basically every 5 months for me) and we don't even track the car.
Current: 08 E90 M3 DCT SSII w/ BE RB Swap, H8 Lux 180s, MS Drop-in AF, CF spoiler, CF diffuser, OEM CF leather trim, CF DCT paddles, Custom DCT flatbottom wheel, MirrorTap 9500ix, RockAuto rotors, Hawk HPS pads, AMS ECU 93 Oct Map Tune, GTS DCT update, Slambo custom undertray
04-10-2018, 05:50 PM | #13 |
3848
Rep 8,625
It's probably fine even if the commute is short. The TSB is likely targeted at people who are only using the car on weekends or never get things up to temp which leads to moisture buildup in the crankcase. If you get it out on the highway periodically I wouldn't sweat it.
04-10-2018, 06:10 PM | #14 |
Rep 1,881
every 3k for me. i dont care what anybody says, oil is cheap.
04-10-2018, 06:11 PM | #15 | |
Rep 1,003
How often does that work out to?
04-10-2018, 06:16 PM | #16 |
Rep 1,881
04-16-2018, 09:39 PM | #17 |
Rep 164
I also change my oil every 3k miles or 6 months.I drive car daily,short trips and 120* F in summer will break down oil fast.
04-17-2018, 10:40 AM | #19 |
3848
Rep 8,625
Easiest way to tell if you're pouring out perfectly good oil is to just get a UOA and pay the extra $20 for TBN + TAN analysis. The plethora of reports shared on this site should make it fairly obvious that you can go longer than 5,000 miles in most cases.
04-17-2018, 11:16 AM | #20 | |
Rep 769
05-18-2018, 04:05 PM | #21 |
Rep 363
Actually, I believe BE recommends an oil change 400 miles post Bearing Job to get the Assembly Lube out of the Oil. I just did it to be safe.
05-19-2018, 07:52 PM | #22 | |
Rep 769
