European Auto Source
      03-07-2016, 11:36 PM   #1
818m3e92
818m3e92's Avatar
Drives: 2011 E92 M3 CP Jerez Black
Problem with my M3.. what is it?
So my M3 does this weird thing and its 2 specific weird things that have happened and I'm hoping someone here knows what i might be or what it is!
2011 DCT m3 e92, 50k miles
1) This has happened 3 times now, i will be in D and waiting at a red light and the rev will be below 1k, and all of a sudden it starts to rev up and down and over again for about 4`5 revs and it goes from 500-1500 like as if i am barely tapping the gas and revving up and down. This is while in Drive and was waiting at a red light 3 times.
2) This is the weird one, so basically i will be driving and it will feel like as i give more gas it jerks and slows down for now reason, and then 3 seconds later its fine? So first time it happened i was in 4th gear and was kind of pushing it and all of a sudden it had a jerky feeling in the pedal and felt like it was slowing down, so i let off and put it in 5th and drove slowly and it seemed fine, second time i was in 2nd coming around a turn and it did the same thing and got a bit jerky and slowed down for 2 seconds as i gave it gas, then i let off and when i gave gas again it was fine, and the last and final time it happened i was in D going on the onramp to the freeway and it had the same jerky slowing down feeling as i gave it gas so i let off and it went away after couple seconds.
So if anyone has had this, or knows what it is or may be, please share I am curious what this is, i have a full AM warranty and hope its nothing serious but if it is SOMETHING that hopefully its covered, thank you all for your input and information!
M Performance, Gintani, Macht Schnell, Ohlins, Vorshlag, yokohama...
      03-08-2016, 02:15 AM   #2
BPMSport
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [3.75]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Send a message via Skype™ to BPMSport
Sounds like an idle control valve or a low pressure fuel sensor to me.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      03-08-2016, 04:08 AM   #3
818m3e92
818m3e92's Avatar
Thanks, I'm curious if there is a way to check if these have gone bad? Because all i know now is from what I've said, or a way to prove that one of these is the problem? Thanks again
      03-08-2016, 04:46 AM   #4
Helmsman
Helmsman's Avatar
Sweden
1437
Drives: 2011 E90 M3 ZCP
Tried to scan the car? Maybe Carly could help provide indications?
      03-08-2016, 06:49 AM   #5
MiamiE93Vert
Drives: E93 M3 Convertible
Check your alternator.
AA Pulley, Air Filter and Tune - Full Evolve Valvetronic Exhaust - 380/355 Stoptech BBK, BBS FI's and other fun stuff.
      03-08-2016, 06:56 AM   #6
KRZ3
Drives: E90 M3
Erratic idle could be the fuel tank breather valve. It does it to me only when outside temp is below 5C and humidity high, and for the first 5 mins, but almost every time when stopping after 100 yards.
Or as Mike said, the idle control valve, or maybe just maybe the spark plugs.
'09 E90 M3 DCT EDC, ESS VT2 625, ESS HFC, GTS DCT, D2R BBK, B16D, VORSHLAG CP, DELRIN SUB, TE37SL
'00 996.1 GT3 CS
      03-08-2016, 01:13 PM   #7
dparm
dparm's Avatar
Drives: Corvette Grand Sport
I'm with Mike -- and I'm leaning towards the ICV or something similar. Those are classic symptoms of a vacuum leak.
Now: 2017 Corvette Grand Sport
Past: 2011.5 M3 sedan ZCP
      03-09-2016, 02:08 AM   #8
818m3e92
818m3e92's Avatar
These symptoms with the idle going up and down while stopped is the same as when I'm giving it gas and it slows the car down? I will have it plugged in to check the computer, as well as the alternator as indicated above and the ICV or Fuel pressure sensor! Thanks to all for the info, hopefully i can get this resolved and figured out!
      03-09-2016, 12:06 PM   #9
dparm
dparm's Avatar
Yes, because there is always vacuum and it will increase/decrease with load. An engine is basically a glorified vacuum pump.
      03-10-2016, 11:11 AM   #10
8600RPM
Drives: e92 m3
Throttle position sensor
Search this Thread:
Advanced Search
