      08-06-2018, 05:30 AM   #1
ironlung
ironlung's Avatar
9
Drives: 335i
Please delete
as per title
03 330CI Sold!
06 325XI Sold!
07 335i | JB4 | 19" Staggered Alufelgen SF-71 | Aero Lip | BMW Performance Spoiler | Matte Black Grill
11 535i Msport | 20" Bavarian BC10 | AC-S springs | Blacked out front grills
      08-07-2018, 11:11 AM   #2
motion732
Drives: E92 M3, F30 335 M Sport
Also interested...
      08-07-2018, 01:03 PM   #3
ironlung
ironlung's Avatar
9
Drives: 335i
Originally Posted by motion732 View Post
Also interested...
Also interested...
are you experiencing the same sounds?
03 330CI Sold!
06 325XI Sold!
      08-07-2018, 05:55 PM   #4
Mvy
Drives: 2008 E93 M3
Get it checked out. Some people remove the clutch return assist spring to make it feel less spongy. Then some level of clunking could be normal. If its not related to that and the assist spring is still in place, some clutch failures can cause a total loss of the vehicle. See below post. A clunk noise alone does not mean you have a clutch spring problem but it might indicate one of the spring straps coming loose causing too much play. It could also be as simple as a worn clutch/flywheel.
https://www.m3post.com/forums/showth...=clutch+spring
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive...
      08-07-2018, 07:13 PM   #5
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
my clutch is pretty noisy but i just assumed it's normal
mine's a 2008
i do hear a single metallic clank/clunk after i reverse and stop (like out of my parking ******* ... but it sounds like it's coming from the rear
edit - actually started paying more attention after posting this
the clank noise is coming from the front, not rear
it was hard to pinpoint the source of the noise when i'm hearing it from one side window
why did the OP delete his post?
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22
      08-09-2018, 09:00 AM   #6
DasboostF80
Drives: 2023 Marina Bay X3M Comp
Glad to hear I am not the only one, I get a clank sound (very metallic) from the passenger rear after coming from reverse and also under deceleration. Its hard to hear under deceleration as you can only hear it in first and second and at slow speeds (wind noise im sure cancels). I had it on a lift yesterday and couldn't replicate it, put it on an alignment rack, rocked it back and forth with one of our techs under the car, we could hear it but not locate it. Sounds like this is a little more common that I thought. My car has 100k on it.
      08-11-2018, 12:02 PM   #7
monterey
monterey's Avatar
339
Drives: 2008 M3
could be the guibo
      08-12-2018, 06:56 PM   #8
Lambro
Lambro's Avatar
29
Drives: 2008 M3 Sedan
So many variables. I have seen loose brake pads and a bad ebrake make clanking noises.
