06-13-2011, 09:08 PM | #1 |
Rep 241
M3 is running hot
On hot days my oil temp needle is close to the dot between 210 and 300 degrees which is approx. 245-250 degrees.
My car is at the dealer right now and they say it is normal for spirited driving. Is it? Seems to me 245-250 degrees is very hot and not good for the engine. |
06-13-2011, 09:11 PM | #2 |
Rep 1,848
It has been 100 degrees here in Texas last several days and my gauge has stayed at 210. I did a 2-day DE this past weekend and it got up to 240 during the sessions.
06-13-2011, 09:33 PM | #4 |
Rep 241
06-13-2011, 09:38 PM | #5 |
Rep 1,848
06-14-2011, 03:40 AM | #6 |
Rep 1,530
Mine gets above 210 every day during my 30 miles "spirited" commute to work. Mostly on the way back when it's 95F outside. Never went to the next mark though. If you keep RPM above 4K most of the time in 95F weather, it has to climb above 210. I think
2011 E92 JB/BL/DCT--->80K Miles
2015 F80 SS/SO/DCT?->28K Miles 2015 Porsche 911S |
06-14-2011, 05:31 AM | #7 |
collecting toys
41
Rep 810
Mine is 210 around town and will hit 240 on the track.
Never seen it above 240 yet...
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy 2006 SLK 55 AMG sold |
06-14-2011, 09:07 AM | #8 |
Moderator
94
Rep 1,920
Seems a bit hot to me....hopefully the dealer will look into it some more for you. As others have said, the "normal" temp is about 210 and 240 under heavy load/track duty.
Although it is actually a good thing to get the oil over 212 occasionally to boil off any water condensation, your temp seems a bit higher than most have reported. Keep on eye on it and keep complaining....have them give it a good once over too. Something doesn't seem right. edit: I am curious how you are driving when you see this temp spike. Are you in traffic a lot or running it hard? I noticed my oil temps go up pretty quickly in traffic on hot days. |
06-14-2011, 10:37 AM | #9 | |
Rep 15,818
That was as I was doing my cool down lap Was above the that 2nd to last mark during the hot laps
IanMan384.00 |
06-14-2011, 10:47 AM | #10 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
not with my TPMS error on like that
06-14-2011, 12:05 PM | #11 |
Moderator
94
Rep 1,920
Prolly has track wheels on...no TPMS (my guess).
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
06-14-2011, 12:35 PM | #12 |
Ninja
390
Rep 4,014
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
06-14-2011, 07:24 PM | #13 |
Rep 241
This is about where I was at but I was not tracking my car.
parameters: 94 degrees 80-85 MPH No A/C I was stuck in traffic about 10 minutes before needle rose Dealer says normal. |
06-14-2011, 09:56 PM | #14 |
Rep 255
After 20K miles of off track driving with some of the same charateristics as you describe, I've never seen oil temps that exceeded 215-220 F. If your car didn't use to do this then there is something wrong. Check for blockage of oil cooler.
06-15-2011, 11:32 AM | #15 |
Rep 5,012
My car reached almost between the 210 mark and the dot in normal, relaxed driving, something it had never done before. Not a problem so far, but will keep an eye on the temp needle more often.
By the way, the most logical problem is the thermostat. Once they start getting 'lazy', they take longer to open, resulting in hotter engine temperatures. If my car doesn't sell, will do a coolant change along with my 2nd annual oil change and see if that helps. Sounds weird having thermostat problems with only 2 years and 8K miles, but it's possible. The question is if I should replace thermostat at the same time as coolant . Need to find out how easy is to do that. Good day. Last edited by JCtx; 06-15-2011 at 11:42 AM.. |
06-15-2011, 11:33 AM | #16 |
Moderator
94
Rep 1,920
You said you were in traffic for 10 minutes before the temp started to rise? Well then i would say it is normal too. If it cools back off once you are underway, I would not worry about it at all, especially if the ambient temps were above 90....
08-16-2019, 01:50 AM | #17 |
Rep 1
I had the same problem. I fixed it by bleeding the cooling system.
https://www.newtis.info/tisv2/a/en/e...-check/Hq5CpsJ Important! The following venting procedure is necessary e.g. when a part is replaced in the cooling system or when the cooling system is refilled. Only when filling!
After I was done, the float showed the system had too much coolant. I removed the excess coolant with a large automotive syringe. About 8 oz total of coolant was removed. My oil temps went back to 210 after warmed up, driving on the highway at 85 mph, outside air temp was 110. I"m in AZ. And, when i park, my cooling fan does not kick on. Before, I bled the system, oil temps were 220 in the same conditions and my cooling fan would kick when i parked the car and turned the engine off. The lesson I learned here is, try the simplest and easiest thing first. Yes, I could have a bad thermostat, failing water pump, clogged radiator or even a stuck oil thermostat (located in the oil filler housing). But before investing all the time and money try the easy stuff first. |
08-16-2019, 06:18 AM | #19 |
General
63358
Rep 24,668
Running too hot (can be) a symptom of extreme bearing wear ...
Regarding the S65 bearings and high oil temperatures ,over the years I saw this issue more than once !
m3jala543.50 |
08-16-2019, 08:00 AM | #20 |
Rep 7,110
Hi Phil, surely once the bearings has started to heat up the oil that much it can only be a matter of (short) time before the go..?
///M Power-Belgium63358.00 |
08-16-2019, 03:20 PM | #21 | |
General
63358
Rep 24,668
That's why the list from the blown engines is still growing , today I added 2 failures for the list => # 2415+2416 https://www.m3post.com/forums/showth...86615&page=110
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 08-18-2019 at 04:10 PM.. |
