01-16-2017, 02:32 AM | #1 |
Rep 87
Changing engine oil grade for the winter?
Just wanted to get an idea of how many actually switch to a thinner viscosity during the winters?
Thoughts on this video below? |
01-16-2017, 10:41 AM | #2 |
Rep 985
Drives: 08 M5 Sapphire Black
Pour test at 10min 30.
I personally use 0w-40 in the winter.....
01-23-2017, 07:35 AM | #3 |
Rep 979
I wonder how many people with M3s actually dont garage them and leave them outside where the oil gets cold enough to make any difference at start up. Even on the coldest days here my car rarely gets below 50 degrees in the winter due to my garage so in my case I have always doubted changing oil weight due to weather is really necessary.
01-25-2017, 04:06 PM | #4 |
Rep 8,075
Drives: 11 E90 M3 Individual
It gets cold here in Wichita...I run 0w-40 from Oct to Mar.
2018 F30 320iX Melbourne Red
01-26-2017, 04:10 PM | #7 |
///M Powered for Life
11469
Rep 10,328
On the E92 I only use 10W60. It is stored for winter
On the E90 which sees some winter use I use 10W60 in winter as well as it has the BE bearings. |
01-26-2017, 04:59 PM | #8 |
Rep 10,594
I use 0W40 year round. No track. If I change my bearings for a second time in a few years to ones with added clearance, I would go back to 10W60, or if I tracked the car I would consider using it during the track season.
01-27-2017, 06:40 AM | #10 |
Rep 922
I use 5w-50 all year round.
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
01-27-2017, 09:05 AM | #11 |
Grease Monkey
293
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
That is because your GTI specs a 5W oil which is not nearly as bad as a 10W in the cold months. With T.O.'s winter temperatures a 5W is fine, besides, VW engines don't run oil clearances nearly as tight as BMW.
01-27-2017, 08:16 PM | #12 |
Rep 3,140
Drives: 2014 M5 6MT
No. I honestly don't see the point. BMW ///M tests all their cars in all environments. If they spec a 10w60, that's what you should use.
2014 M5 6MT
01-27-2017, 09:10 PM | #14 |
Stop the hate, get a V8
3850
Rep 8,625
LMFAO, a funnel pour test? What does that even prove? Oil is pumped out of the pan, it isn't poured out. There is an actual pumpability test which represents how engines really work. See below explanation:
https://www.bobistheoilguy.com/forum...Number=1836257
Past: 2011.5 M3 sedan ZCP |
01-28-2017, 10:53 AM | #16 | |
Grease Monkey
293
Rep 2,646
01-28-2017, 01:05 PM | #17 |
Rep 3,140
Drives: 2014 M5 6MT
I'm still waiting for someone to show the community, clear unbiased information regarding environmental temp and bearing wear. To my knowledge there isn't any correlation between the two. Colder oil is thicker, but no one has proven this creates or accelerates bearing wear. You can go ahead and speculate all you want, until someone shows clear evidence that colder weather increases wear with 10w60, there is absolutely no reason to switch oils in colder weather.
2014 M5 6MT
01-28-2017, 08:07 PM | #18 |
Rep 10,594
There is the general concepts that 10W60 is thicker than 0W40 and that in winter any oil pours more slowly than when warm. And there is a general concern that stock bearing clearance is on the tight side.
01-28-2017, 08:44 PM | #19 |
Rep 3,140
Drives: 2014 M5 6MT
But there is zero evidence to prove that 10w60 is too thick for proper lubrication during winter temps. Everyone who switches does so because the internet told them too... no other reason at all. There is zero evidence that 0w40 helps in any way.
2014 M5 6MT
01-28-2017, 08:45 PM | #20 | |
Rep 1,792
01-28-2017, 08:47 PM | #21 |
Rep 10,594
I have observed that, along with people changing to extra clearance rod bearings. What bearings did you use when you changed?
01-28-2017, 08:55 PM | #22 | |
Rep 3,140
Drives: 2014 M5 6MT
Note: If the oil analysis shows any copper in the system, the bearings are already toast and need to be changed. The reduced lead and copper counts in the 0w40 samples proves nothing to me. You can't rely on blackstone for your argument. There have been many reports of clean OA reports being followed by engine failure shortly after. I'm in the distorted rod bore camp. That's my theory as to why the bearings wear prematurely. Not actual oil clearance, but distorted rod bores creating metal to bearing contact under load. Something that is fixed with new bolts torqued to the proper spec, with correct clamp load values on the rod end.
2014 M5 6MT
