09-21-2022, 08:29 PM | #1 |
Rep 193
Dinan high performance adjustable coil-over
Installed for about 500 miles, sold the car and had everything removed. Dinan Part#: R190-9131 Compatible w/ OEM EDC Shocks - E90/E92/E93 Features: Quietest Coil over kit on the market so you can live with it every day. Beehive shaped front spring and low profile camber plates to maintain full suspension travel with up to one inch of lowering. Threaded collars allow easy front & rear vehicle height adjustments. Included suspension packers allow adjustment of bump-stop clearance to fine-tune handling and comfort. Dinan-spec progressive bump stops improve ride quality at lowered ride heights. System comes with adjustable camber plates allowing easy camber adjustment between -1.2° and -3.2°. Camber plates are machined from 6061-T6 aluminum, and are designed with heavy-duty rubber and barrel shaped Delrin internal components for superior performance and quiet operation, compared to noisy spherical bearing mounts. Front & rear Dinan components are compatible with 2.50" I.D. racing springs. Compatible with BMW EDC shocks.
'23 M3 50th Jahre Interlagos Blue
'22 M4 Frozen Brilliant White '18 F80 M3 CS Lime Rock Grey '16 F86 X6M Brilliant White '13 E92 M3 Frozen Edition Brilliant White (My unicorn - Best Day Ever! ) |
09-22-2022, 12:40 AM | #2 | |
Rep 51
-2013 135IS-
JB4, 40% Ethanol, Cobb Charge Pipe, 4' Catless downpipe, Injen intake |
