09-16-2015, 05:53 AM | #1 |
Rep 1,247
Cleaning buffing pads?
I just bought a used porter cable that came with a bunch of 6.5 inch pads. But they look pretty dirty. How could I clean these pads instead of replacing them?
2009 E92 BMW M3.
09-16-2015, 07:17 AM | #2 |
Rep 103
Chemical guys has a pad cleaner that works well for removing the polish from the pads. Spray it on, then let it soak in warm water for about 10 minutes. Works great.
09-16-2015, 12:57 PM | #4 |
Rep 5,506
+1
Works great. Spray on power dissolver and then rub and rinse. I used to buy it from Walmart off the shelf but it looks like it's not available anymore. It looks like you can buy it from Amazon labeled as a professional product.
Auto Detailing Enthusiast!
09-16-2015, 12:59 PM | #5 |
Rep 953
I have had good luck with Chemical Guys pad cleaner.
| 2011 M3 Sedan | Le Mans Blue | M-DCT | ZC2 | ZCP | ZP3 | Moonroof | Enhanced Premium Sound | Dinan exhaust | Dinan software | Dinan pulley | Dinan intake | Dinan pedals | Bimmian LED interior | Lux H8 V3 | WeissLicht PY24W LED | 20% tint | IND reflectors | IND front grills | IND key hole cover | IND hood vents | IND M5 mirror covers | Reus Systems audio | Verstraβe shifter paddles | BBS LM 20x9 et 15 and 20x10.5 et 15 | Hankook Ventus V12 255/30/20 and 295/25/20 | Red BBS Racing lug nut kit | H&R Sport springs |
09-16-2015, 01:20 PM | #6 |
Rep 6,696
Drives: F30 340i
09-16-2015, 03:41 PM | #7 |
Rep 1,247
09-16-2015, 03:58 PM | #8 |
Rep 5,506
Power Disolver is not dish washing detergent. It is a spray that you spray on and then the polish just dissolves as you rinse out the pad. It is pretty powerful stuff. I guess that is why they don't sell it off the shelf anymore in retail stores.
09-16-2015, 04:18 PM | #9 |
Rep 1,247
Thank you for the input Also do you have any idea if buffing pads can be purchased at any kind of local store such as pepboys or can they only be ordered online?
2009 E92 BMW M3.
09-16-2015, 05:25 PM | #10 |
Rep 5,506
Most polishers enthusiasts or detailers use have a velcro back plate that hooks up to the pad that way. You will not find anything like that at local stores.
09-17-2015, 05:29 PM | #12 |
Rep 187
Just checked Walmart's website, evidently Power Dissolver has been discontinued and is only sold as a "professional" cleaner now through online retailers. I've heard Greased Lightning works on pads also, I'll pick up a bottle today and give it a shot.
09-18-2015, 04:20 AM | #14 |
Rep 1,247
Thank you for the info. Ill check them out.
2009 E92 BMW M3.
09-18-2015, 04:23 AM | #15 |
Rep 1,247
Thats what I was recommended by Detailed Image. I think Im going to get the snappy clean powder. Seems like an affordable product. By the way this is going to be the first time for me using a porter cable or any kind of power buffer so Im pretty nervous. How do you buff the small areas on the car such as the paint just above the door between the roof and door? Or just any small area?
2009 E92 BMW M3.
09-18-2015, 12:45 PM | #16 | |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
When new to machine polishing, best to use a fine/finishing polish to get the hang of it, nothing too aggressive. |
09-18-2015, 05:24 PM | #17 | |
Rep 1,247
Xmt 180 high gloss carnauba wax. Also a variety of lake country 6.5" pads of which are kinda beat up. So I've ordered some new 5.5" pads from detailed image being my pads are beat up and 6.5" which seems a bit big for a 5" backing plate. I just did the trunk lid only using the swirl remover 2 with an orange pad, swirl remover 1 with gray pad(because I don't have white pad yet), and finishing glaze with a blue pad. 6.5" was too big for the 5" backing plate. But the trunk lid looks better except for where it meets the little trunk lip. Not sure if those scratches were there, or if I caused them? Could I have caused those scratches? |
09-18-2015, 06:18 PM | #18 |
Woof!
352
Rep 1,323
If the car was pretty clean and free of any grit when you started, it is unlikely you caused the scratches. The area immediately in front of the rear lip does trap bits of junk and can accumulate scratches as people wipe off the car over the years (especially dry wiping it). Scratches from a polisher would generally be semi-circular in shape, rather than linear. Also, as you bring up the surface gloss of a vehicle, some imperfections that were not visible or obvious can show up that were previously masked by a dull finish.
09-18-2015, 06:57 PM | #19 | |
Rep 1,247
2009 E92 BMW M3.
