INDustry distribution
      03-30-2018, 02:04 PM   #1
DToxic
DToxic's Avatar
Drives: MW E92 M3
HELP! O2 Sensor or Secondary Air Pump/Valves?
My 2013 E92 M3 is giving the following 2 faults after I completed a spark plug change (intake plenum removed):
1) 274B DME oxygen sensor pump current calibration error before cat converter bank 2.
2) 27B0 DME secondary air system flow rate bank 1
I verified the secondary air pump (SAP) is working by feeling the vacuum pull on cold start, but I can't verify the air pump check valves (ACV) are opened without more invasive investigation.
What are your thoughts? Do you guys think these two faults are related to the O2 sensor even though they're different banks? Do you think these faults coming right after a spark plug change are coincidental?
I think a quick chicken test would be to swap the O2 sensors and see if the faults follow the sensors...but would really like to avoid the SAP and ACV...
Thanks in advance!
      12-10-2018, 10:11 AM   #2
waldron80
waldron80's Avatar
Drives: 08 e90 M3 6MT
Ever figure this out? I also have 27B0 showing up. Repalced o2 and SAP and code still shows up.
      01-19-2020, 09:55 AM   #3
waldron80
waldron80's Avatar
Bump
      02-04-2020, 12:26 PM   #4
RYDEM3
Philippines
13
Drives: ///2008 e92
I’m currently on the same boat with 27B0 secondary air bank 1 “increased emmisions” was hoping changing out spark plugs and pre cat 02 sensors would do the trick as others have been successful with, pumps are working. Just looking to rule out other things before tackling down replacing the hose/valves altogether
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
