04-04-2024, 01:18 PM | #1 |
Rep 167
2011 M3 repeatedly destroying crankshaft pos sensor on high rpm pull
Hey guys have an odd one for you. My car is making contact and destroying my crankshaft position sensor on high rpm pulls 7k- redline. Has anyone run into this before? I'm about to have my transmission torn apart to see what it is but figured I'd ask the community first.
04-04-2024, 06:08 PM | #2 |
Rep 1,855
I've only ever had it vibrate loose, but not get destroyed, but which one are we talking about?
there is two, one in the lower portion of the trans and one at the side which iirc is the RPM sensor.
04-04-2024, 06:35 PM | #3 | |
Rep 167
Here are the pictures, the groove you can see on the top something in my trans is causing. View post on imgur.com Last edited by CjM3; 04-04-2024 at 06:42 PM.. |
04-05-2024, 05:09 AM | #4 |
mTekMods
2248
Rep 2,996
you verified thats the correct cps? if youve troubleshooted this and verified there are no obvious issues then pull the transmission out.
04-05-2024, 10:20 AM | #5 |
Rep 1,855
yeah that's crazy... lol that might have to be a transmission pull and internal inspection as amrazM said.
DCT and 6SPD use the same part number and it also looks to be correct. but verify.
04-05-2024, 12:52 PM | #6 |
Rep 167
Good times lol, trans coming apart monday. Will let you guys know the results.
04-05-2024, 01:39 PM | #7 |
Rep 4,066
manual car? I wonder if a spring or something on the clutch came loose and is hitting it
04-05-2024, 04:37 PM | #8 |
Rep 167
04-08-2024, 05:07 AM | #9 |
mTekMods
2248
Rep 2,996
pressure plate straps more than likely.
