07-26-2016, 05:10 PM | #1 |
Rep 173
Need help...Location of RDS Antenna
Does anyone know where the RDS antenna is located in the E92 M3?
Thanks
Mauricio Cardoso
08-25-2016, 12:45 PM | #3 |
Rep 2,907
Drives: 2011 E93 M3
You mean RDC? RDC/TPMS module is in the rear quarter panel above the battery.
RDS is Radio Data System- it's not a module. |
09-18-2016, 11:50 PM | #4 | |
Lord Scrip
1812
Rep 3,013
Drives: 2011 M3 Coupe
10-07-2016, 04:21 PM | #5 |
Rep 173
I found it guys, it's on the driver side behind the front wheel. Directly under where your left foot rest is.
Mauricio Cardoso
10-15-2016, 05:57 AM | #7 |
Rep 2,907
Drives: 2011 E93 M3
Why are you calling that RDS? BMW calls that the RDC antenna. That's probably why you didn't get any replies.
10-26-2016, 11:38 PM | #8 |
Rep 173
I'm getting a code for front left so it may not be the RDC antenna after all (I meant to say RDC in the original post).
I checked the module and the RDC antenna and they look fine, no dirt or corrosion at all. Will update this weekend, thanks for the replies.
Mauricio Cardoso
11-14-2016, 02:42 PM | #9 |
Rep 173
Codes
I'm getting the same codes even after clearing them and swapping the left and right TPMS signal sending unit (square box in the wheel well).
Mauricio Cardoso
12-18-2016, 02:45 PM | #10 |
Lord Scrip
1812
Rep 3,013
It was behind my rear passenger side tire. Remove the aluminum dirt shield and it's plugged in right there. No need to jack up the car, just lay down behind tire with two sockets. 2011 E92
12-15-2018, 04:19 PM | #11 |
Rep 140
12-15-2018, 05:37 PM | #12 | |
Rep 173
Mauricio Cardoso
12-17-2018, 07:13 AM | #13 |
Rep 140
