02-28-2016, 08:38 PM | #1 |
Rep 8
Thermostat replacement Code P0128/Water pump
My car currently has code P0128 so I was going to replace the thermostat and coolant sensor. Would it be best to get the water pump replaced at the same time?
My car is 08 E92 with 57,000 miles on it. The temp guage is below or at half when it warms up. Any help would be appreciated. Thanks, Dustin |
02-28-2016, 09:37 PM | #2 |
Rep 2,301
The water pump is very durable, and should be good till about 140K miles. Just do the thermostat, and change the thermostat housing O-rings as well, or you'll leak.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
02-29-2016, 05:57 AM | #3 |
Rep 398
Agreed, I would just do the thermostat.
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune |
12-16-2018, 06:01 PM | #4 |
Railside Performance
48
Rep 331
Drives: E92 M3 R8 V10 Q5
Garage List 2010 Ducati Streetf ... [7.00]
2017 Q5 [0.00] 2017 BMW R NineT Racer [5.00] 2010 Audi R8 V10 Ma ... [0.00] 2008 M3 [10.00] |
I just had this happen to my E92 M3 this week with the "increased emissions" on the Idrive and yellow engine symbol and when I hooked up the scanner it showed P0128. I checked my coolant level and it was on the low end, so I topped it upped with coolant and distilled water and reset the code. No new code since and the car runs great, so am I just lucky or are some people changing thermostats just because the garage says so? I hope this may help.
E92 M3 Manual
R8 V10 Manual / Audi Q5 Ducati Streetfighter 1098 / BMW R NineT Racer Ducati Monster 796 / Ducati Bronco 1964 Railside Performance |
12-17-2018, 06:32 AM | #5 |
Rep 191
In my case, I had the code cleared and it came back after 2 months, so changed thermostat & coolant sensor at 60,000 miles. I've heard thermostats on these cars go out quite often around 60 to 90,000 miles.
Will change it again around 110,000 miles along with water pump & serpentine belt, pulley tensioners |
