04-26-2018, 10:27 PM | #1 |
Rep 1,170
Lci tails issue
Hey guys made the swap a while ago. I coded out the errors but does anyone know what the heck these lights are and why they are now my daytime running lights?
Check my for sale and wanted threads!!! If i didn't post sold then it's still available!!
http://www.e90post.com/forums/search...&starteronly=1 |
04-27-2018, 12:23 PM | #2 |
Rep 1,170
Cant for the life of me figure out what the hell this light does
04-27-2018, 12:44 PM | #3 |
Rep 18,821
Drives: BMW
Convertible inners have different wiring on the inner lamps than pre LCI. Just need to swap the wires to the correct positions.
04-28-2018, 08:45 AM | #4 |
Rep 1,170
So i was using the Carly App and noticed that somehow there are daytime running lights for “inner break lights” was switched on. I switched them off and they are no longer on during the day. But switch back on when my headlights come on. Is there a way to code that out? Or would i have to do something with coding? Thanks
05-21-2018, 01:10 PM | #5 |
Rep 1,170
bump has anyone figured out how to fix these on the e93 lci? can't seem to find through searching. Also getting flashing when i start the car up. flashes about 10 times.
05-31-2018, 01:39 PM | #6 |
Rep 1,170
bump! anybody somebody!
I think i read something somewhere about replacing a module for an updated one. I guess i could just take the rear fog bulbs out. theyre so damn bright at night!
05-31-2018, 08:39 PM | #7 |
Rep 102
I remember reading that selected pre-LCI cars might need to swap out the FRM to the latest FRM3 module in order to “complete” the LCI taillights update. That said, some also claimed that you don’t need that module. Could be confusing but I guess perhaps you might wanna research more about that? Sorry can’t be of any help.
06-09-2018, 11:07 AM | #8 |
mTekMods
2142
Rep 2,901
Yeah you may need a later FRM for LED tail licht.
06-10-2018, 10:51 PM | #9 |
Rep 1,170
Damn ive got the carly for bmw this thing seems useless now
06-10-2018, 10:59 PM | #10 |
Rep 742
Revert your frm to stock settings and recode the tail lights. Just turn off all the tail light bulb checks. If that doesn't work you'll most likely need ncs expert to disable them when headlights are on. I'm not 100% sure but I believe all Lci tail lights are plug and play with coding, but someone above mentioned it is a wiring thing with convertibles so I'd do a bit of research on the forums.
06-11-2018, 11:09 AM | #11 | |
Rep 855
OP, do you understand what is meant by swapping the wires? You don't need a new FRM but you will need to code out the lamp checks. For now, put everything back that you coded in carly until you straighten out your wires.
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
06-12-2018, 12:13 AM | #12 |
Rep 1,170
Any idea which wires i need to swap! I think i did this on my 2007 e90 when i swapped to lci
06-20-2018, 05:50 AM | #13 |
Rep 1,170
Bump! Has anyone has to swap these wires??
07-06-2018, 04:08 AM | #14 |
Rep 553
Looks like the "Follow Me" lights. I had them on my Benz and I saw in the carly app as well. Be sure to check that it's off in both sections. By both sections I cant remember the letters but for some coding, you have to code in two different sections to change something.
07-06-2018, 12:25 PM | #15 |
Rep 1,170
I think it must be wiring. I might be able to code out the lights but it looks like the wiring is powering on the follow me/fog lights instead of the leds
