12-22-2015, 08:13 AM | #2 |
Field Marshall
307
Rep 515
To the OP, I only recommend products here after extensive use and experience. I also tend toward simplicity, I try and use the least amount of product and stick to what works over time. My detailing closet is not overwhelmed with many different types of cleaners, my only disclaimer being that the products for paint correction have improved so much over the past 5 years, so it's hard to keep up with those! I use this product to clean all of my interior surfaces:
http://www.autogeek.net/1z-einzett-cockpit-premium.html I have been using this product exclusively for several years, some here might say that it has the propensity to dry out leather surfaces, however, I have not experienced this phenomenon. I do use Leatherique once a year on all leather surfaces as a preventative measure, my leather still looks new after 4 years and you would swear that I have a new steering wheel on my car. The product referenced also does a great job of cleaning the iDrive screens without leaving residue or streaking behind. I use a clean microfiber on which I introduce a little of the product and then spray lightly on surfaces to be cleaned. I stress that microfiber gives you the best result without streaking. You might need several passes to clean your steering wheel if it has a lot of ingrained dirt and oils. I recently completed a full interior detail on the wife's A7 and she was blown away - "my car is better than new!" direct quote. Hope that this helps! PS: I purchase the product in bulk (10 liter typically). Autogeek has a Gift Certificate sale right now where you are able to purchase a $200 gift certificate for $160. An idea might be to purchase yourself such, and then turn around and use it to purchase the 10 liter and some of the smaller spray bottles of the product. I have three of the spray bottles which I refill from the 10 liter container. Just an FYI, I have no affiliation to Autogeek, I am an equal opportunity detailer purchasing from Detailers Domain, Autogeek and Chemical Guys. |
12-22-2015, 01:40 PM | #3 |
Rep 878
I've been using SONAX Leather Foam and I can attest that it is an outstanding product.
www.detailersdomain.com
-WJV
12-22-2015, 02:51 PM | #5 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
I would caution you not to over-clean a steering wheel. Sometimes when it is rubbing off black it is the leather dye and not just dirt. Liquid cleaners in combination with years of handling can result in a sudden softening and breakdown of the leather finish. Removal of any part of that finish is not a pretty sight, and will feel dried out. Sometimes it is better to leave steering wheels to age naturally (at least the leather parts). Also, cleaning tends to spread black discoloration onto the colored stitching (on wheels that have that-- like an M3).
12-23-2015, 03:17 PM | #6 | |
Stop the hate, get a V8
3850
Rep 8,625
To clean the stitches, I just use a few drops of laundry soap in warm water and a toothbrush.
Past: 2011.5 M3 sedan ZCP |
01-01-2016, 09:34 PM | #8 | |
Rep 957
01-05-2016, 10:30 AM | #12 |
Rep 1,320
Try sonax leather foam first (gently). If that doesn't do the trick, Try Swissvax or leatherique.
Does the shiny surface feel oily or is the feel consistent across the surface? |
01-06-2016, 07:56 AM | #14 |
Rep 1,320
I've never used leatherique, but I've only heard good things about it. I don't want to be the one to tell you to buy it, because I'm not 100% sure it's the correct product for this application.
I hope somebody else can chime in here. One another note, that's a really odd place to wear on the steering wheel....How do you hold the wheel when you drive? |
01-06-2016, 08:25 AM | #15 |
Rep 2,361
I've steam cleaned my entire leather interior, including the steering wheel, and you won't believe the amount of dirt/grime removed from the leather fibers. After that, I used leatherique products to restore the proper oils back onto the leather.
The leather literally feels like new now |
06-01-2016, 10:58 AM | #19 | |
3850
Rep 8,625
Older cars, or those that have been driven more, will probably just be dirtier by nature. What's happening is that the dirt and oils from your skin are actually polishing the leather over time, hence the shiny/smooth appearance. Same thing happens on the seats (your pants will basically act like sandpaper as you move around). It can be very tricky to undo that short of having the wheel re-wrapped. It's why a bit of routine maintenance goes a long way to slow down that process. I also advise people to use some diluted laundry soap and warm water to clean the steering wheel stitching. Just use a toothbrush to scrub it every once and a while.
07-15-2016, 06:55 AM | #20 |
Rep 615
Drives: E92 M3 6MT Space/Black
The Leatherique 2 step process is a great product when you use both the rejuvenator oil first and let it sit for a few hours in the heat, and then come back to clean it off with the Prestine Clean liquid. (yes it's spelled "prestine") What all this does is softens the leather, draws out the grime and hand oils and then the cleaner washes away all grime and takes away the shine that develops on the wheel after gripping it for months at a time. The leather takes on that soft, matte factory new feel.
Give it a try! I am happy with how well it works. I have a 6spd so the left hand side of my wheel gets the treatment twice as often, lol. GM |
07-15-2016, 10:28 AM | #21 |
Rep 1,930
I've used leatherique on my steering wheel and if you rub too hard the dye will start coming off. You can tell because originally you can see the grains on the surface. I'm going to try swissvax next to see if there is any improvements.
07-15-2016, 10:49 AM | #22 |
Rep 1,522
I love using chemical guys leather cleaner on my steering wheel.
2016 MW ZCP F80 M3(current)
2016 SO ZCP 6MT F82 M4(sold) 2015 MW 6MT F80 M3(sold) Individual Hellrot ZCP E92 M3(sold) |
