01-04-2019, 07:50 PM | #2 |
Rep 742
I recommend searching this online before posting as you're going to get roasted on this question.
#1. Check the bulb, swap from one side to the other see if it follows. If it follows then your bulb is bad, replace bulb (h8) #2. If the swap bulbs and it stays on the not working side then it could be your ballast as those have a tendency to go out. #3. Buy a diagnostic tool, scan the frm and see if you are throwing a short circuit fault. If so, then you need to reset it via tool32 to reset the counter to get it to power on. |
01-04-2019, 08:25 PM | #4 |
Rep 369
The guy is from Malaysia and English is probably not his first language. Give him a break.
01-04-2019, 08:40 PM | #5 |
Rep 12
em
Wong
01-04-2019, 08:42 PM | #6 | |
Rep 12
Wong
01-05-2019, 11:20 PM | #7 | ||
Rep 742
01-05-2019, 11:49 PM | #8 | |||
Rep 12
Wong
