12-05-2023, 06:47 PM | #1 |
Rep 20
M2c brakes on a E92 M3
Hey guys
I’m looking to retro fit m2c front and rear brakes on to my e92 m3. They make an adaptor for the front calipers but I was wondering if the rears would be bolt on? Has anyone done this swap? Thanks |
12-06-2023, 02:03 PM | #2 |
Rep 5,550
The R F8x brake kit requires an adapter to make the 2-piston caliper and rotor to fit on an e9x m3 rear which would suggest the M2C rear 4-piston caliper and rotor also would require an adapter kit to make the M2C rear brakes to fit on the rear of an e9x M3
12-07-2023, 05:12 AM | #3 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
I have done it.
https://www.m3post.com/forums/showpo...&postcount=116 https://www.m3post.com/forums/showpo...&postcount=117 Did not use brackets up front but F87 camber correcting spindles. In post 117 you can see the washers my tech had made to fit the rear calipers. Check out the whole sticky brake thread started by tdott. |
