10-12-2023, 03:59 AM | #1 |
Rep 9
E92 M3 Rear Toe Arm Spherical Bearings
Hello,
Does anyone have any info on whether the Spherical bearings on the rear arms are replaceable, if so what part number? or does the whole arm have to be replaced. https://www.fcpeuro.com/products/bmw...m3-33322283549 https://www.fcpeuro.com/BMW-parts/M3...ds=33322283545 Thank You Last edited by cvcvc; 10-12-2023 at 04:24 AM.. |
10-12-2023, 03:28 PM | #2 |
Rep 645
They theoretically are replaceable but unless you have a press and proper tooling it's way cheaper/easier to just buy new arms.
Edit: see below. Spherical side is non serviceable. Last edited by amg6975; 10-13-2023 at 12:20 PM.. |
10-12-2023, 06:22 PM | #3 |
Rep 4,167
If they are built similar to the other stock arms with spherical ends then they are not replaceable. The bearing is swaged into the arm, it's not pressed in. Trying to press it out will damage the arm.
10-13-2023, 12:15 PM | #5 |
Rep 20
The rubber bushing can be replaced with a spherical bearing and a special conical washer. The other side isn’t replaceable, but then again should not see much wear/play. If you search there is a whole thread on solid rear bushings.
