07-30-2016, 03:47 PM | #1 |
Rep 20
Engine issue - includes error codes.
- Fault: Bad way detection
- Code: 002789 - Fault: Ambient temperature - Code: 00278A - Fault: Misfire with cut-out cyl 7 - Code: 002B3B - Fault: check at lower top - Code: 002B57 - Fault: check at lower top - Code: 002796 - Fault: Misfire with cut-out 5 Cyl - Code: 002B39 - Fault: Misfire with cut-out 6 cyl - Code: 002B3A - Fault: Misfire with cut-out 8 Cyl - Code: 002B3C - Fault: Misfire with cut-out several cyl - Code: 002B41 - Fault: Misfire with emissions deterioration 5 Cyl - Code: 002B46 - Fault: Misfire with emissions deterioration 6 cyl - Code: 002B47 - Fault: Misfire with emissions deterioration cyl 7 - Code: 002B48 - Fault: Misfire with emissions deterioration 8 Cyl - Code: 002B49 - Fault: Deterioration cyl misfire with emissions more - Code: 002B4E Lots of smoke out of the exhaust, immediate engine management warning light, limp mode happened once. I'm thinking O2 sensor or injectors (possibly being optimistic) but has anyone had this happen and therefore might be able to point me in the right direction. E92 M3. |
08-07-2016, 04:11 PM | #2 | |
Rep 263
R3DVelvetM3
