      01-19-2025, 03:31 AM   #1
aggieshan
Drives: E92 M3 LCI 6MT
Belly panel Wheel housing cover bolts PN 07149126886 or 07147129160
I have trying to find the correct bolts for my e92 M3 and e92 335i belly pan and wheel arch covers. From realoem,
https://www.realoem.com/bmw/enUS/sho...diagId=51_5862
https://www.realoem.com/bmw/enUS/sho...diagId=51_5860
07147129160 seems to be the correct PN. However, these bolt's washers are smaller than the ones on my cars. They don't look correct to me. The one that looks very closed is 07149126886 but it is not shown as M3 belly pan parts on realoem. On ecstuning, 07149126886 appears to be the same bolt on my M3 and 335i.
Any idea on the correct PN?
2003 E39 540i M Sport 6 speed
2009 E90 328i Sport 6 Speed
2013 E92 M3 Base 6 speed
2013 E92 M3 Comp 6 speed
      01-20-2025, 10:36 AM   #2
deansbimmer
deansbimmer's Avatar
4142
Drives: 2011 E93 M3
1988 E30 M3  [0.00]
2006 E46 M3  [0.00]
2024 X7 M60i  [0.00]
2011 BMW M3  [0.00]
BMW installed two types of these trim screws in these cars depending on what they're attaching and when it was built. Your LCI cars would have come with the coarse thread 886 to secure items like the undertray parts. You can often confirm what's required by whether the "threaded" nut plate is dyed green- those require the coarse thread screws with the wide washer.
Throughout the car you'll still find the 160 fine thread screws used. You need to keep both types on hand as you'll need both from time to time.
Helmsman4798.00
kolosy2028.00
      01-20-2025, 07:30 PM   #3
aggieshan
Thank you very much. Finally, screw type mystery got solved. I am going to order some 886 for my LCI e92. I will take a look at nut plate dyed green color. How did you figure out these two screw types?
Search this Thread:
Advanced Search
