08-08-2013, 07:56 AM | #1 |
Rep 6,783
Help, key acting strangely
I've recently used a key which had been sitting around for awhile and it behaves a little erratically. Sometimes the alarm goes off on its own, the lock button stops working temporarily, or the unlock button opens the trunk.
Could the key battery be depleted? And if so, does it get recharged when put in the ignition slot? Or do I need a new battery? I don't have CA, just the regular key with the alarm option. Any suggestions would be highly appreciated!
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
08-08-2013, 08:16 AM | #2 |
Rep 4,124
Could be a low battery. Not having CA means the key charges while in the ignition slot. Let it recharge and see if that resolves your issues...
2021 X3 M40i
08-08-2013, 12:53 PM | #3 |
Rep 869
If the battery is way depleted it may not recharge. I would just change the battery in the key fob, it opens up and has a small camera-like battery that you can buy at the drug store.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
08-08-2013, 02:13 PM | #4 |
Rep 4,124
Hmmm... Be careful when replacing the battery on a non-CA car. CA equipped cars use a non-rechargeable watch battery available at any drug store but non-CA equipped cars use a rechargeable battery. Not sure those are simply available at the drug store...
2021 X3 M40i
08-08-2013, 03:06 PM | #5 |
Rep 869
Mine is CA, and is rechargeable, and is replaceable, too. I wasn't aware of the difference between the non-CA.
08-08-2013, 06:12 PM | #6 |
Rep 4,124
CA keys are not rechargeable, they use a simple CR2032 battery. You can put the key fob in the ignition slot but it does not charge. The non-CA key does charge in the ignition slot... It has been this way since CA was introduced, having had CA on my '08 550 and and my '11 M3.
2021 X3 M40i
08-08-2013, 06:39 PM | #7 |
Rep 588
How long should a CA key battery last?
2013 E92 M3 (the weekend good weather car), 2018 Tesla Model 3 Performance (the 20k mi/yr beater)
08-08-2013, 07:10 PM | #8 |
Rep 4,124
Good question! I changed my battery for my M3 key a couple of months ago as it seemed to not work consistently. Had never changed the battery on my Sept 2010 built car so 2.5+ years. What I can't be sure of is if the dealer ever changed it for me during a normal service. Never changed my key in three years of owning my '08 550 but I think the dealer changed it once during a regular service.
2021 X3 M40i
08-08-2013, 08:23 PM | #9 |
Rep 588
So I guess changing every 2 yrs would be a good pattern to follow. I've got a zillion CR2032 batteries around. Maybe I'll throw a set in the glove box.
08-08-2013, 08:29 PM | #10 |
Rep 4,124
Agreed on the 2 yrs but I have never experienced an outright failure. I have noticed the CA not working as advertised on occasion and that is usually a good indicator to change the battery...
2021 X3 M40i
08-09-2013, 07:03 AM | #11 | |
Rep 869
So, there is never a need for me to plug in my CA key into the ignition slot? I'll continue to just change out the battery.
08-09-2013, 07:34 AM | #12 |
Rep 4,124
Correct, no need to plug in the key. Only time mine has been plugged in by the occasional valet who doesn't know the system. Otherwise it stays in my pocket.
2021 X3 M40i
08-09-2013, 11:00 AM | #13 |
The mod bug has bitten.
23
Rep 563
Drives: 2008 M3 Sedan
Going on 5 years here and I've never replaced the battery in my CA key. Still works like a champ.
08-16-2013, 12:26 AM | #14 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
I have had my fare share of CA issues with bmw's (long story) My wife's key was going nuts so I did this. Replaced the battery, used the key in the fob to lock/unlock the care, then put the CA fob in the dash, start the car, shut it off, remove the fob and all was well. I read this in another thread and it worked like a charm. worth a shot.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
