09-18-2018, 06:03 PM | #1 |
Rep 209
Stripped oil pan
Went into Schomp Bmw today for an oil change and they told me bolt on the oil pan is stripped and won't go back on. I was quoted $1640 if it can be repaired and $3464 if the pan needs to be replaced.. Does anyone have experience with this? Any other alternatives?
"If you ain't first, you're last!"
09-18-2018, 06:39 PM | #2 |
Rep 656
There are many theads on this. Do an advanced search for stripped or pan in title only. Here is one I found for you...
https://www.m3post.com/forums/showth...&highlight=Pan Time cert is what you need and is a permanent repair. Most shops can do this for you. |
09-18-2018, 07:37 PM | #3 |
Rep 12,724
its definitely not a $1,600 job for a repair. don't go to that guy, he's nuts. indy shops charge a couple hundred bucks for a fix plus new oil/etc..
09-18-2018, 07:53 PM | #4 |
Rep 10,610
$1600 would be a day of expensive big city labor to remove pan, helicoil or keene sert, and reinstall with fresh oil and filter. You can fix it on the car instead for a fraction of that price.
09-18-2018, 08:10 PM | #5 | ||
Rep 209
09-18-2018, 08:11 PM | #6 |
Rep 724
As mentioned earlier that price suggests they are removing the pan. Installing a timesert with the pan in place can be done, but can be installed incorrectly (happened to me). Because of the crush washer, it is critical that it installed square to the existing hole. Otherwise issues can arise. If you've been thinking of doing the rod bearings, this would be a good opportunity as removing the pan is about 1/2 of the job.
If you're going to have it repaired in place, try finding a shop that specializes in spark plug thread repair. I regret not going to the one near me. |
09-18-2018, 08:22 PM | #7 | |
Rep 209
09-18-2018, 08:45 PM | #8 | |
Rep 12,724
even with a complete oil pan replacement, they have to move the subframe. that is why labor is so high. it can be repaired, just find a confident and competent shop in your area.
09-18-2018, 08:56 PM | #9 |
Rep 209
Could you link me to the correct time sert kit to buy? Thanks!
09-18-2018, 09:15 PM | #10 |
Rep 12,724
sorry man, i haven't done it myself. people seem to have good luck with this product. i don't know which thread they go with.
http://www.timesert.com/
09-18-2018, 09:51 PM | #11 | |
Rep 209
09-19-2018, 09:43 AM | #14 |
Rep 724
Not sure if still available, but has size.
TIME-SERT M12 X 1.50 for sale https://www.m3post.com/forums/showthread.php?t=1340000 |
09-19-2018, 12:25 PM | #15 |
Rep 1,932
Drives: 2013 E92 M3
09-19-2018, 02:03 PM | #16 | ||
Rep 209
UPSROD945.50 |
