07-14-2021, 12:02 AM | #1 |
Rep 61
Increased Emissions* 2AF9 2B59 2AFD
The other day, I had an engine overheating message and the oil gauge went to 250F but fell back down instantly when I pulled over.
Fast forward to today, I had an increased emissions light with these 3 codes Fault code: 002AF9 Coolant temperature sensor Fault code: 002B59 Coolant thermostat monitoring Fault code: 002AFD Relative time plausibility The car seems to drive normally with the only exception being it takes a lot longer for my oil temp. to reach 210F (where it usually stays at when I cruise) Also want to add that I changed the thermostat about 2 years ago while I was changing my water pump. I just want to confirm that this problem sounds like the coolant temp. sensor Part # 13621433076 |
