07-06-2021, 04:41 PM | #1 |
Rep 193
Please help: X-pipe ball to muffler socket leak
Hi all,
Yesterday I bought and installed an oem x pipe with test pipes onto my car with an AA rear. The shop I took it to used a pry bar to get the ball of the xpipe into the mufflers socket and in doing so bent the muffler's flange outward. While driving home I noticed a nasty leak from the rear so guessed it was that connection. Long story short I put the car on ramps, took that clamp off and saw this.. hammered it down as much as I could and started the car. The nasty leak sound was gone but there's still a ton of air coming out. Any advice on how to make this fully seal without welding or making this connection permanent? Appreciate it! |
07-06-2021, 05:41 PM | #3 |
Rep 193
07-06-2021, 06:01 PM | #4 |
Rep 3,997
Give it a few taps with a hammer to see if you can get it back into close shape and hope the clamp does the rest.
07-06-2021, 06:12 PM | #5 |
Rep 12,739
I'm not sure what you're asking, but the clamp on your pic is done. It's stretched and flattened. There's no going back, get new clamps.
07-06-2021, 06:23 PM | #6 | |
Rep 193
The flange on the muffler was bent outwards due to a pry bar being used to get the x-pipe to go into the muffler, I couldn't flatten all of it down due to not enough room so was asking if the new clamps will help reform that oringinal shape. Will get new clamps asap though, thank you for the advice! |
07-07-2021, 05:07 PM | #7 |
Rep 12,739
No, you'll have to bend it back yourself. Don't let the person who used the pry bar work on it again. It fits together fine without a pry bar. Loosen the rear muffler if it's tight… it's a couple of bolts.
Hivand_M138.00 |
07-11-2021, 01:49 AM | #8 |
Rep 193
With the old clamps on and the x-pipe/muffler warmed up it helped reform the shape again over a couple days.
I did get and install new clamps which definitely helped seal it up even more. Thanks for the advice roastbeef AA rear, oem xpipe with primaries deleted sounds delicious. |
roastbeef11594.00 |
07-11-2021, 09:17 AM | #10 |
Rep 193
I looked into this but very briefly, thought it was permanent. Will definitely give it a shot next time either the muffler or x pipe come out since I still felt the slightest bit of air coming out even after fitting the new clamps. Thanks!
