08-21-2015, 12:21 PM | #1 |
Rep 383
Misfiring - Only one bank?
What are the possible causes for misfiring on ONLY one bank of cylinders (cylinders 5-8)?
Pulling codes has only told me the cylinders are misfiring (duh) but hasn't pulled anything to help isolate the cause. Thanks. |
08-21-2015, 01:55 PM | #2 | |
I know a thing or 2 about a thing or 2...
3104
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
http://www.m3post.com/forums/showthread.php?t=1158519 You also look up the codes here: http://www.bmwforums.info/bmw-electr...es-list-3.html
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
08-21-2015, 02:23 PM | #4 |
3104
Rep 3,470
Well, I thought it did. Wasn't haven't any problems, but now it's back. I haven't replaced another sensor (they are ridiculously priced now and hard to find) so I've been slowly going back to stock to see what is causing it.
08-26-2015, 02:18 PM | #6 |
Rep 383
Anyone?
Is this mic on? Edit - Yesterday the car went through 4-5 drive cycles without one misfire or code. Then late last night it started again just idling in a parking lot. Misfired on cylinders 5-8 and an O2 code on deceleration. Need some help! Thanks. Last edited by douglee25; 08-26-2015 at 02:24 PM.. |
08-26-2015, 10:36 PM | #7 |
3104
Rep 3,470
Re-seated and swapped bank 1 and bank 2 sensors. So far so good. Cleared codes and haven't gone into limp mode. FYI, the only time this happens is at idle. I'll report back if I still have a problem, but I think it's your O2 sensors.
08-27-2015, 08:31 AM | #8 | |
Rep 383
For what it's worth, last night I swapped back in the O2 on bank 2 that was new as of March/April 2015. For reference the one that was in today on bank 2 was the old one from bank 1. Bank 1 never threw a code previously so I figured it would be fine. That O2 has been in the car on bank 2 since June 2015 or so? I swapped them back in June (new for old) because I was still getting some random O2 codes on bank 2 and I wanted to see if the swap would fixed it. The newer O2 sensor on bank 2 never gave me misfires though, only some random codes. We will see what happens. |
09-01-2015, 08:29 AM | #9 |
Rep 383
Update 9/1/15 - 6 days after putting an older O2 back in on bank 2....
I haven't had one misfire or engine code. I will continue to monitor things and see if that is really the cause. I was not under the impression that O2's could cause misfires? Engine codes, yes. Misfires, no? Has anyone else seen that? |
09-23-2015, 03:49 PM | #10 |
Rep 383
Update 9/23/15 -
I've been running for 4 weeks now with the old O2 sensor and zero codes or misfires. I think I can positively state that the issue was with the O2 causing the misfires. And for the record, the throttle actuator never did show up during my code scans. |
09-23-2015, 06:41 PM | #11 |
Rep 542
also test your alternator, same thing happened to me, the "rough idle and bam limp node on hot day "
dealer says the alternator is not charging, change it and its good so far |
09-24-2015, 08:32 AM | #12 |
3104
Rep 3,470
Glad things are better. Just had a horrible day again the other day. Car was going into limp mode and almost couldn't the car home. Pulled codes and the same errors. VKAT Bank 2. Fortunately, I had bought a used one from a member. Changed it out and all is better. I just don't understand why this sensor keeps going bad.
05-30-2021, 12:22 PM | #14 |
Rep 23
douglee25 ,
i have exactly the same symptoms as you: car getting into limp mode, either while idling or while going really slow. have you concluded in the end that the O2 sensor fixed your issue ? I am only getting misfires on 5-8 with shutdown of the whole bank. no other codes come up, so I am a bit confused as to why it would not just mention that there is a faulty O2 sensor, or O2 sensor reading.... i have swapped the throttle actuator between banks and the error stayed on the same cylinders.
'08 VW Polo GTi / '09 VW Touareg V6 TDI
'91 E30 325i Cabrio / '03 E39 530d Touring Individual / '11 E93 M3 Last edited by monkishor; 05-30-2021 at 12:29 PM.. |
06-20-2021, 07:47 PM | #15 | |
Rep 817
Drives: 2013 E92 M3
Car went into limp mode today yet again with only the Bank 2 cylinders misfiring. I also keep getting this 27B1 (secondary air system throughput bank 2) 275E (lambda control stop error bank 2) or 2751 (lambda probe error pump current line before kat bank 2) |
06-23-2021, 09:00 AM | #16 | ||
Rep 23
I have narrowed it down (i hope) to an exhaust leak on the left side, which I believe is just before the o2 sensor. exhaust sounds like a hemi v8 at idle and sounds like it has a hole in the exhaust when driving it through a tunnel. it would make sense because its only going in limp mode when at low rpm, as I believe the low pressure in the exhaust allows it to suck in false air and sends the o2 sensor the wrong values. when reving it hard, the gas just goes out, so the o2 sensors are getting the right reading. i have ordered the gasket, which apparently is known to fail, but did not have time to change it. will let you know if that is the case. hope its not a hole in the exhaust 😂
'91 E30 325i Cabrio / '03 E39 530d Touring Individual / '11 E93 M3 |
06-24-2021, 04:52 PM | #17 | |||
Rep 817
Drives: 2013 E92 M3
06-24-2021, 05:22 PM | #18 |
Rep 1,751
take a pic of your O2 sensor and post it. i want to see how they look
07-05-2021, 04:30 PM | #19 | |
Rep 23
when we got under the car and took off the exhaust we realised that there was no gasket on the left hand side... after we put the oem gasket on and changed the one on the right side, the car has changed COMPLETELY. the sound is now smooth and linear... absolutely no more trembling when idling and the car now idles straight at 600rpm. before there was a small fluctuation and it was always idling around 7-800rpm. it all makes sense now... because probably the o2 sensor was getting a wrong reading and therefore was chocking the engine at idle, causing the "broken exhaust" sound, skaing and fluctuating idle. I can now say that the problem was for sure coming from this. i am absolutely shocked by how the engine runs now... sorry I did not take a picture of the O2 sensor because we did not take it off. only took off the bolts from the exhaust and that allowed us to put in the new gasket without having to take off the exhaust. we literally did this on the side of the road and it took us around 1 hour in total. (it actually took us more time to put back the cover from underneath the engine than to actually change the gaskets)
07-05-2021, 08:48 PM | #20 | |
Rep 1,751
07-08-2021, 09:22 AM | #21 |
Rep 5
The plugs where the Pre Kat O2 sensors are plugged in, are often slightly corroded or wobbly.
They must always be properly tightened Clean with contact spray then with a small needle something in it scratch/clean and with 2-3 cable ties, for testing, the plugs tightly together so that they hold together even at high Revs or start and always have contact. This connection often causes mysterious, but not exclusively, O2 error messages.
3pdls.com
07-10-2021, 01:14 AM | #22 | |
Naval Aviator
666
Rep 694
Same issue a month ago. Replaced #8 coil [would have done all but no aftermarket inventory nationally] Replaced RT bank plugs. Running great now.
Performance Mods: Alpine Stage II; SuperSprint config: non-resonated front+X-pipes+F1s; cat-less; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK |
