01-19-2021, 06:06 PM | #1 |
08 e92 m3 6MT AW
14
Rep 40
kw clubsport install questions
Hi,
I installed KW clubsport 2 way coilovers which have the latest spring rates (110 nmm front and 120 nmm rear). I bought the 140 nmm rear springs (from the old version) from KW to swap out but it was 20 mm shorter and I would therefore need to raise the adjuster 20 mm which went over the max height of the adjuster. I'm assuming the older version of the CS had a higher adjuster or longer helper springs. Anyone did this swap before who can describe what they did? I also reused the rubber pad at the top of the rear shock (see circled item in pic) since I couldn't figure how to take it out. I'm assuming this is ok. Can anyone verify? For the front, I have to order new sway bar end links since the oem are too long. I've seen some KWs which came with end links, but mine didn't. Overall not too bad an install. Now I'm going to let it settle and then get an alignment. |
