07-22-2016, 10:58 PM | #1 |
Rep 1,024
Anyone experienced this and figured out how to fix it or any ideas?? It flickers super fast when it should pulse on. My car is a 2008 with upgraded LCI's.
Thanks in advance
07-22-2016, 11:53 PM | #2 |
Rep 92
Drives: 2011 E92 M3
I'm having similar issues to my drivers side. Started off with my low beams flickering when hitting bumps to all lights malfunctioning (angel eyes, low beams, turn signal).
My guess is that it's either a loose wire or a faulty control unit. I'm leaning towards a faulty control unit. I'm also interested in any answers you may receive. Yours can be as simple as a loose wire, bad bulb, or as complicated as a faulty control unit. |
07-23-2016, 12:32 AM | #3 |
Rep 545
Because the left side is doing the quick flash you have missed a bad bulb or connection on the left side. One of the left directional bulbs front or rear is the cause of your problem.
By closely looking at the good right side you will discover where all the flashing bulbs are located. |
07-23-2016, 12:35 AM | #4 | |
Rep 1,024
07-23-2016, 12:36 AM | #5 | |
Rep 1,024
07-23-2016, 12:51 AM | #6 |
Rep 545
07-23-2016, 12:58 AM | #7 |
Rep 1,024
Left front bulb is working but flickering fast as well. Is that just a symptom of bad bulb going out?
07-23-2016, 01:10 PM | #8 | |
Rep 545
I'm still with you trying to help, so I went back to study the manual/documents again. (Note: I have a 2008 non LCI E92 M3 so I cannot confirm on my vehicle.) BMW uses "adaptive bulb" locations in rear lighting. If your turn signal bulb burns out there is a "adaptive" bulb location that the control unit can use to light the needed corner. There might be a chance that this is your problem discovering the problem bulb. This is a diagram of the rear bulbs for a 2013 model so should be like the LCI version in your vehicle. These are the descriptions for each location. Looking at the GOOD right side might also help with where the bad bulb is located on the left. Do you have a "bulb warning" on your iDrive screen with this problem? •Bulb, direction indicator light (1) •Bulb, reversing light (2) •Bulb, brake light (3) •Bulb, brake light/adaptive brake light (ECE) (4) |
07-23-2016, 03:04 PM | #9 | ||
Rep 1,024
07-23-2016, 05:03 PM | #10 |
Rep 545
With that iDrive warning it should be the #1 bulb "direction indicator light" shown in the diagram. Bad bulb or bad connection. If the bulb tests good with an ohm meter then check the bulb and socket contacts. I have had the contact problem in my car. I keep spare tail light bulbs in the car.
Also be sure to use the correct bulb or the control system will continue to display a fault in the iDrive. Some after market bulbs do not have the correct electrical resistance. Quality bulbs do not have this problem. I am not sure the diagram matches the LCI bulb assembly? |
07-23-2016, 05:06 PM | #11 |
Rep 998
unplug the battery and reconnect magic will happen
2008 E92M3 6SPD stripper
2011 E90M3 DCT baby hauler 2010 997.2 GT3RS 3.8 weekend warrior |
XKxRome0ox1587.50 |
07-24-2016, 12:39 AM | #12 | |
Rep 1,024
are u serious? lol Guess it wont hurt to try?
07-24-2016, 10:13 AM | #13 |
Rep 545
Save the labor charge! Just swap the turn signal bulbs left and right sides to see if the problem changes sides. OR install a new bulb which is cheaper than the labor rate of having a technician test the old one. It's a good Sunday project.
07-24-2016, 11:08 AM | #14 |
Rep 6,723
Since you have LCI lights, you should have LED's and not bulbs.
If you have LED's, check to see if all of the LED's are lighting up. You may have intermittent issues with the circuit board. If this is the case, you'll have to replace the whole assembly. If you have LED's, turn on the left signal and just watch the tail light. You may see an occasional instance where most of the LED's won't light up. I had this issue on my car. Last thing to check is if your lights have a bad resistor if it's an aftermarket LCI kit or factory with coding. Aftermarket light kits can cause problems. |
07-24-2016, 11:32 AM | #15 |
Rep 998
You suppose to have the car coded if you go with LCI taillights, otherwise the car will be acting weird, like fast blinker etc. My car does the same once in a while, but I have been lucky enough to fix it by disconnect and reconnect the battery.
07-24-2016, 09:53 PM | #16 | |
Rep 1,024
07-24-2016, 09:55 PM | #17 | |
Rep 1,024
07-24-2016, 11:10 PM | #18 |
Rep 6,723
07-24-2016, 11:15 PM | #19 |
Rep 998
no, i do not see any bulb out for almost 4 years since I went LCI. The same problem does come back once in a while, but reconnect the battery always does the trick for me.
07-25-2016, 01:08 PM | #20 |
Rep 172
07-25-2016, 07:30 PM | #21 |
Rep 998
No, didn't do any coding. Car is totally fine except fast blinkers once in a couple month, it does not mean that every car go lci will behave the same tho.
2011 E90M3 DCT baby hauler 2010 997.2 GT3RS 3.8 weekend warrior Last edited by ailikesiliu; 07-25-2016 at 07:36 PM.. |
08-29-2016, 12:30 PM | #22 |
Rep 172
Wow, I can't believe that worked! Saved me the trouble of needing to get it coded. I can't believe I didn't do this earlier. I was living with the fast blinker for months. Thanks!
