02-11-2017, 03:01 PM | #1 |
F15 daddymobile
2350
Rep 3,510
Tire size input: Yikes! 20s?
Looking like my new wheel setup is:
20x9.5 et19 20x11 et25 I'm currently lowered on swift springs w/OEM EDC Was wanting to run 265/30/20 and 295/30/20 MPSS. Does anyone see any issues with running this setup and tire combo? I realize that this will be slightly larger than the OEM ZCP spec setup and I'm ok with that. I just want to make sure these will fit. Tire sizes are limited in 20s and I don't want to run a 2025 profile tire.
02-11-2017, 03:13 PM | #2 |
Rep 93
Will be seriously tall and there is a good chance of rubbing I would suspect, and be well over OEM tyre height - I am running 255/30/20 and 275/30/20 on 9" front and 10.5" rear.
My call would be 255/30 front and 295/25 rear - or even a 305 rear - 30 profile on rear with that width will just be too tall. Either way you are going to be way outside the OEM 20mm front to rear stagger as well. Last edited by tomfraser; 02-11-2017 at 03:19 PM.. |
Maxf80M3174.00 |
02-11-2017, 03:19 PM | #3 |
F15 daddymobile
2350
Rep 3,510
when i run the calcs they're only showing .5" taller than OEM sizes. My concern with running a narrower tire is stretch too. don't want stretch.
02-11-2017, 08:23 PM | #4 |
Rep 12,725
you'll rub. i'm on oem zcp suspension and oem zcp wheels with 275/30/19's. i might rub a tiny tiny bit at full lock up front on the inside rear part of the wheel well. your 265/30/20 is 0.7" taller.
i have also ran 275/35/19's up front (because i got them at a good price) and they definitely rubbed. the 275/35/19's are the same diameter as the 265/30/20's, so i'd say you'll definitely rub at full lock. what wheels? a bbs 3piece? you could always build them for 20's and downsize to 19's later. i think it is difficult to get 20's to look/fit right on these cars.
02-12-2017, 02:30 AM | #5 |
Rep 513
I personally find 20s to be a bit too big on an E90. Looks great/fine on an E92 though, larger arches in the rear.
255/30/20 max up front. Anything else is just way too tall and you'll rub, and the car will look a little weird IMO. I believe you can run a 305/25/20 in the rear if you want, should be ok. |
02-12-2017, 01:05 PM | #6 | ||
F15 daddymobile
2350
Rep 3,510
02-12-2017, 08:40 PM | #7 | |
Rep 513
02-12-2017, 09:00 PM | #8 | |
Rep 12,725
i'm referencing my front tire size right now (275/30) that might rub a tiny bit. 275/30/19 diameter = 25.6 265/30/20 diameter = 26.3 unless its completely over my head, thats a 0.7" difference. the 0.3" difference is with the 275/35/19's and the 265/30/20's, in which the 265/30/20's are slightly smaller, but i think they will still rub. whats on my fender liner is more than 0.3" of rubbing. i'm no expert, just trying to help from my little experience.
02-12-2017, 10:28 PM | #9 | |
F15 daddymobile
2350
Rep 3,510
roastbeef11584.50 |
02-14-2017, 09:47 AM | #10 | |
Boost Addict
174
Rep 460
F80 BMW M3 DCT YMB
2008 BMW E93 6MT, Ess VT2 625 |
02-14-2017, 05:57 PM | #11 |
Rep 6,734
You are kindof screwed. You have no choice but to run stretched tires in the front and rubber bands all around. That's why you don't want 20's on an e92... Your proposed tire sizes won't work without rubbing. You will need 255/30/20 front and 285/30/20, 295/25/20 or 305/25/20 in the rear. You will be adding a bunch of stagger and most likely under steer at the limit with the drastically wider rear tire. You probably don't care about that if you are running 20's.
'23 X7
02-20-2017, 11:19 AM | #14 |
Rep 6,734
I bet that's because you are running 9" wheels in the front with 255's. OP has 9.5" wide wheels which will stretch a 255/30 tire. I realize looks are subjective but the e9x both looks and performs significantly better with 19's or 18's. I just think 20's with rubber band tires look silly on this platform. I'm basing this on actual experience as I had 20's on my first M3.
'23 X7
02-20-2017, 11:36 AM | #15 | |
Boost Addict
174
Rep 460
F80 BMW M3 DCT YMB
02-21-2017, 09:09 AM | #16 | |
Rep 6,734
'23 X7
Maxf80M3174.00 |
