02-27-2023, 12:52 PM | #1 |
Rep 191
E92 Removing Rear Seats effects the rigidity?
I'm trying to understand if removing the rear seat will effect the cars rigidity on track?
Technically it should but tying to know up to what extent. Can I go to track days like that without a half roll cage? |
02-27-2023, 02:18 PM | #2 | |
Rep 510
Explain your thought process here. -Duke |
DrFerry6728.50 |
02-27-2023, 03:33 PM | #4 | |
Rep 510
1/4” cold rolled steel, or a small simple wire frame with wrapped cushion material and some leather? It will help with weight reduction and that’s it. It has zero impact on suspension geometry or unibody chassis. -Duke |
ashutoshkotha38.50 DrFerry6728.50 |
02-27-2023, 03:57 PM | #5 |
Rep 191
Got it. I’m just getting started on my build. That is what I hoped it’d be.
Thanks for responding! |
DukeofAlexandria633.00 |
02-27-2023, 04:31 PM | #6 |
Rep 3,410
Beware, It’s addicting to just keep taking shit out! ashutoshkotha
02-27-2023, 05:22 PM | #8 |
Rep 3,410
One day it will be, right now it’s just a mess… Have fun
02-28-2023, 01:10 PM | #10 | |
Rep 2,824
Example on the E46: Sedan (w/o folding seats): 18000Nm/deg of torsion Sedan (w/folding seats): 13000Nm |
ashutoshkotha38.50 chocstraw495.50 |
03-26-2023, 10:09 PM | #11 | |
Rep 191
12-17-2023, 10:50 AM | #13 | |
Rep 5,549
DrFerry6728.50 |
12-17-2023, 05:55 PM | #14 |
Rep 4,167
I have a cheap Ultra Racing rear strut bar and it helped with rear rigidity even with my folding seats in place. Yes I know it doesn't tie in with the rear strut towers (which are lower) and yes it's not triangulated to the floor etc etc but it works and is noticeable. You can try that if you're worried about rear rigidity without the seat in place.
12-18-2023, 01:35 AM | #15 | |
Rep 5,549
A front strut brace doesn’t increase torsional stiffness like 99% of the internet thinks - it helps to keep the outside loaded strut tower coroner from flexing outward by using the stiffness of the much less loaded inside strut tower. The ultra racing rear strut tower bar is mimicking what a front strut tower bar does. I doubt it increases the stiffness in any DOF by any significant amount. |
12-18-2023, 08:34 AM | #16 |
Rep 4,167
Absolutely nothing scientific. I had a creak from my parcel shelf every time I went over a bump. After the rear strut bar no more sound. I also noticed some additional rear stiffness and less body roll, something like an arb. So something somewhere stopped flexing.
12-18-2023, 09:00 AM | #17 | |
Rep 5,549
However, it won’t have a measurable effect on rear bending and torsional stiffness. Last edited by M3SQRD; 12-18-2023 at 09:05 AM.. |
