05-25-2020, 10:02 AM | #1 |
Rep 215
Seized Engine
11.75 E90 M3 6MT
130k kms (81k miles) Rod Bearing serice history is unknown, likely original. Oil was changed less than 2k ago with BMW branded 10w60. Factory tune, only engine mods are test pipes + gintani axleback. Was doing some harmless donuts/burnouts yesterday outside my buddy's shop and the car just stalled out suddenly without warning. No crank after that. No loud thud or smoking, not a drop of fluid on the ground. Just engine shut off right away. I thought maybe it was a broken engine ground strap but it wasn't. Rolled it right in and threw it on the hoist, pulled out the fan and intake to turn the engine by hand. She is seized up good. Pulled out all 8 spark plugs. Looked good. Car is not throwing any codes. Drained the oil to inspect for any metal shavings, oil was clean. So I'm thinking my rod bearings seized right onto my crank? If that's the case and the engine stopped immediately is there a chance the engine is still salvageable? I'm worried it's my main bearings. But obviously no way of knowing until I drop the oil pan and look. Hoping to get some feedback based on my circumstances. I'm already sitting on another E92 M3 with a blown engine (purchased that way) so I really would prefer not to have two expensive dead bodies on my hands. Pic of my car where it died. |
05-25-2020, 11:51 AM | #3 |
Rep 486
@Assimilator1: Count it!
DanMpower3234.00 Assimilator1591.50 |
05-25-2020, 01:46 PM | #5 |
Rep 68
Drives: 340i M-sport
No such things as harmless burnouts and donuts.
13
Frozen570.00 velociti181.50 BanjoPaterson160.50 EuroStep62.00 K-M390.50 davesaddiction390.50 Ngilbe361618.50 WhiteM3EMC116.00 b4hand661.00 Colinv64016.50 BeaterM3167.00 JDM_CL992.00 waterpanda40.00 |
05-25-2020, 02:25 PM | #6 |
Rep 10,613
This engine was already on its way to failure before the burnouts and donuts. Not doing them would have made driving a lot less fun and the engine would still have failed. Who wants their motor to fail before they have gotten to enjoy burnouts and donuts?
Enjoy the car. Fix it when it breaks. And consider doing preventative maintenance such as rod bearings. If it’s the main bearings, you are exceptionally unlucky. |
05-25-2020, 02:28 PM | #7 |
Rep 215
05-25-2020, 02:29 PM | #8 |
Rep 215
05-25-2020, 02:32 PM | #9 | |
Rep 215
Still of course need to drop the oil pan and see what's going on. But if its not a main bearing failure and the rod bearing seized onto the crank I wonder if this motor can be saved without breaking the bank. |
05-25-2020, 05:02 PM | #10 |
Rep 2,336
Possible that one injector was stuck open.
Three Pedal Steve874.50 |
05-25-2020, 05:13 PM | #11 |
Rep 3,001
Also possible.
Happens frequently with 2011 models apparently.
INSTAGRAM: GORDON.M3
ItsGary1457.50 |
05-25-2020, 05:16 PM | #12 |
Rep 2,738
I don’t know about these cars and the injectors but I had a buddy hydro lock his AMG from leaking injectors. He learned AMG motors are pricey. Very very pricey lol
05-25-2020, 09:11 PM | #13 | |
Rep 10,613
05-27-2020, 11:31 PM | #14 |
Rep 860
Well at least she went out in a blaze of glorious donuts.. with the picture to prove it. Most of them just blow up driving to work at 45mph.
Best of luck. We would all like to see what happened inside that engine I'm sure..so hopefully you'll post updates.
Drifter2090909.50 Theodore668.50 |
06-07-2020, 01:34 PM | #15 |
is fast cars
391
Rep 2,137
wet sump + donuts = possible oil starvation
Daddy's Rocket Sled!
Clarkson: "It is... pretty much perfect... Why don't I have one of these cars?" Harris: "The saloon is definitely the M3 of choice." |
06-07-2020, 02:09 PM | #17 |
Rep 57
I still can't believe how many times this happen and people still won't replace the rod bearings. It just doesn't make sense not do bearing.
If your engine is toast you could have spent $2500 for a little extra insurance. Good luck spending under $10,000. |
SYT_Shadow11479.50 |
06-07-2020, 09:05 PM | #18 |
Rep 4,249
Drives: 2017 M3 MG/SO ZCP DCT
Curious how long were you doing the burnouts and what rpm range you were holding?
06-07-2020, 09:52 PM | #19 |
Rep 2,747
I've never seen oil pressure drop doing donuts.
9ers
Expressivedrives249.00 |
06-08-2020, 03:38 PM | #21 |
Rep 215
I got another engine guys. I'll drop the new motor in and see what happened with the old one after I pull it out.
06-08-2020, 04:06 PM | #22 |
///M Powered for Life
11480
Rep 10,328
The S65 'wet sump' handles 1.4G, more than other 'dry sump' systems
