05-20-2020, 09:21 AM | #1 |
Rep 3,408
Would greatly appreciate insight into where folks are placing the pins on the interior bar. And did you have trouble getting a tight hood fit when closed? Mine has a slight gap.
My struggle is the head of the pin is too long, would be great if they offered a smaller option. I'm not using a nut above, instead a single washes above and a washer nut and jamb nut on the bottom. Only way I could get it low enough. I might see if they have alternative hardware.
05-20-2020, 11:20 AM | #3 |
Rep 3,408
Appreciate that, but this is specific to the aero catch mechanism. This isn't factory, and yes the factory fitment was a bit lower.
05-20-2020, 05:47 PM | #5 | |
Rep 3,408
Was just curious how others installed or if they had similar issue with getting the pins to seat far enough down. I probably should've flipped the orientation and used the metal bracket holding the original hood catch mechanism.
05-21-2020, 02:16 AM | #6 |
Rep 1,617
I'm just curious... why is this needed? Is it because it's an aftermarket lightweight CF hood that doesn't secure well enough with the stock solution?
I've only been black flagged once for a slightly bouncing hood, and that was because I didn't close my stock hood properly. |
05-21-2020, 08:49 AM | #8 | |
Rep 3,408
kyippee1072.00 |
05-26-2020, 10:58 PM | #11 |
Rep 6,734
3 lbs
'23 X7
roastbeef11583.00 |
05-27-2020, 01:55 AM | #12 |
B.E.
444
Rep 761
Here shows where mine is mounted. You can see where I used to have them mounted, like yours, and had to trim down behind it in order to get the hood to close flush. Racewerkz said I installed it in the wrong position and they put it in the correct spot for me, pictured.
Current: 2022 TRX & 2010 GT3RS
Past: 2016 M3 Individual Grigio Telesto Pearl, Sakhir Orange/Black Full Leather w/ CF trim, 6MT, ZCP, CCB, etc... Previous: 2011 E92 M3 Melbourne Red on Black 6MT ZCP. --> now 2010 dedicated track car |
05-27-2020, 02:52 AM | #13 | ||
Rep 6,734
'23 X7
DRLane3985.50 |
05-27-2020, 08:31 AM | #14 | |||
Rep 3,408
I did the same. Used a washer as a stop on top, and then doubled the nuts below to create a jam. Made a couple other adjustments and I'm very close now. Just a couple millimeters off from where it sat with the OEM latches.
slicer2736.00 |
05-30-2020, 09:39 AM | #16 |
Rep 3,408
Add hood clearance? There are little black rubber height adjusters for the hood. Try that.
05-30-2020, 10:37 AM | #17 |
Rep 2,869
05-30-2020, 10:51 AM | #18 | |
Rep 2,869
Will have to see if this solve the issue. Thank you |
05-30-2020, 12:06 PM | #19 | ||
Rep 3,408
05-30-2020, 12:28 PM | #20 | |||
Rep 2,869
DRLane3985.50 |
05-30-2020, 02:09 PM | #21 | ||||
Rep 3,408
05-30-2020, 02:15 PM | #22 | |||||
Rep 2,869
