  TireRack
      12-21-2010, 01:48 AM   #1
1cleanm6
1cleanm6's Avatar
Armenia
236
Drives: M6 GC
Guys need some ps2 width help please!
hey guys,
someone with a 295/30/19 michelin ps2 UNINSTALLED can you please measure and tell me how wide it runs in inches?
I have some 295 ad08s and need to compare, i think the ad08 is much bigger(atleast half inch eventhough they are both 295). Please try to be exact as every mm matters.
thanks!
      12-21-2010, 02:03 AM   #2
sensi09
Drives: .
Are the AD08s 295/30/19 too?
If you go to tirerack and compare, it shows a section width for the PS2 of 11.9. ADO8 is 11.5
You might try the company websites as the numbers sometimes slightly vary.
      12-21-2010, 02:04 AM   #3
1cleanm6
1cleanm6's Avatar
Armenia
236
Drives: M6 GC
If you go to tirerack, it shows a section width for the PS2 of 11.9. ADO8 is 11.5
i just measured my ad08s and they are closer to 12 inches.
Their inch has to be wrong,
my 285/30/19 ps2s show as 11.4 which 295 ad08s show 11.6 and trust me theres way more then .2 difference its night and day.
      12-21-2010, 02:06 AM   #4
sensi09
Drives: .
How wide are your wheels?
Those measurements are standarized for a 10.5 inch rim I believe.
      12-21-2010, 02:08 AM   #5
sensi09
Drives: .
Originally Posted by tirerack
Because a tire's section width is influenced by the width of the rim upon which the tire is mounted, the correct industry assigned measuring rim width for the tire size being measured must be used.
The width of a tire mounted on a narrow rim would be "narrower" than if the same tire was mounted on a wide rim. NOTE: because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width.
The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10".
      12-21-2010, 02:09 AM   #6
1cleanm6
1cleanm6's Avatar
Armenia
236
Drives: M6 GC
19 x 10.5,
im running a 285/35/19 ps2 with a 5mm spacer and im perfectly fine, no rubbing at all, im trying to see if i can run a 295 ps2 without the spacer
      12-21-2010, 02:13 AM   #7
sensi09
Drives: .
Hmm okay not sure why you got closer to 12", perhaps inflation difference.
      12-21-2010, 02:24 AM   #8
sensi09
Drives: .
I'll answer your PM here. I honestly don't know, but think it would be very close.
If you go strictly by section width, the 295 is much wider so that would worry me even without a spacer.
Maybe find someone with your suspension setup and see what they have fit before.
Search this Thread:
Advanced Search
