02-26-2024, 01:48 PM | #1 |
Rep 54
Fault 600A - EDC conrol unit internal fault
Have this error when scanning my 2012 comp e92.
The EDC button does nothing when pressing it. I also get the shock symbol on my instrument cluster when shutting off the car "Dynamic damping control malfuntion!" inside the BMW computer. I checked the connections on the front shocks they look great and I unplugged and replugged them back in. Is it safe to say it's the module itself? I did get another module off of eBay it showed up today. Do I have to disconnect the battery to install it or can I just pop it in? Will it need coded? It did not come out of a comp car and I know the comp ones are setup a little different, but I am unfamilar with coding so I would have to learn first. Can this be coded from the Bimmercode mobile app or only with a D-Can cable using NCS Expert? Any advice or help would be appreciated, thank you! |
02-26-2024, 02:03 PM | #2 |
Rep 2,021
module or SZL / clock spring. you should scan it to see. EDC module needs to be coded i believe. always a good idea to unplug the battery when mucking around with module connections. no real downside. probably can't be coded with bimmercode, you need ista, ncs or protools.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
02-26-2024, 02:25 PM | #3 | |
Rep 54
02-26-2024, 02:39 PM | #4 |
Rep 7,110
Hi Pete,
no coding needed when I replaced mine with a used module. This was a comp pack module going into my comp pack car. I believe it will work fine in yours although you will miss the dynamic damper in Sportmode (whether you notice it). I did not unplugg the battery, just turned ignition off. |
02-26-2024, 05:47 PM | #5 | |
Rep 54
Tags |
600a, coding, edc, module |
