09-19-2013, 08:10 AM | #1 |
Rep 893
Nail in tire, TPMS problem
A few weeks ago I was fortunate enough to have a nail in my tire. Not realizing the problem, I drove around for a couple of weeks before the low tire alert came on, followed shortly by the TPMS malfunction . After examining the tire and seeing the nail, I took it and got it plugged. After this, I reset the TPMS via the button on the dash, but it's not wanting to reset.
Everything was fine pre-nail, then suddenly its acting all weird. I'd rather not take it to the dealer. What are the chances the nail messed up the 1 (or all) TPMS's? It should be noted these are RS Technic TPMS's. |
09-23-2013, 04:57 PM | #3 |
Rep 7,298
i dont see how it would have "broken" the tpms unless the nail went directly through the valve stem. Try resetting but you have to be at a standstill.
09-24-2013, 10:13 AM | #4 | |
Rep 893
I have ordered the BT tool to help solve this issue. I'll post up when I figure it out. |
09-24-2013, 11:44 AM | #5 |
Rep 7,298
09-24-2013, 02:14 PM | #6 |
M3Post Supporting Vendor
87
Rep 964
Is it warning of incorrect pressure? Or is it saying TPMS malfunction? It is possible that when they fixed the tire, they didn't put the right pressure in. Or that some other tire has the wrong pressure for an unrelated reason.
Another theory: Did they dismount the tire and patch it from the inside as well as plugging it? If so, maybe the sensor was damaged during dismount/remount. The odds of the nail harming the sensor are low, but not beyond possibility. If the puncture is within range of the valve stem, the nail could have spiked the sensor part if you were exceptionally unlucky.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
09-24-2013, 02:23 PM | #7 | |
Rep 893
The error i'm getting is the TPMS malfunction. They dismounted it and plugged the tire from the inside, I stood there and watched them. He put 35psi in it. Also, the nail was nearly in the center of the tire. I'm going to check my pressures tonight. |
09-24-2013, 03:46 PM | #8 | |
87
Rep 964
Is your car a fairly early year for the E90? We are getting to the point where cars of the 08 vintage could have sensor batteries dying.
09-24-2013, 04:01 PM | #9 | |
Rep 893
09-28-2013, 02:42 PM | #11 |
///M Enthusiast
28
Rep 442
Drives: 2012, E92 DCT M3
Any luck? I had the same exact situation happen...took a nail smack in the center of the right rear tire . I kept the vehicle parked & used the kit to put air in the tire and seal the hole. Replaced the tire and now all 4 TPMS' are indicating low pressure although all are properly inflated. Reset the system and no love
09-29-2013, 08:38 AM | #12 | |
Rep 893
09-29-2013, 05:15 PM | #13 |
Rep 893
Just read the codes:
604E Error:Tire Pressure Control-system Error will cause a warning light Error is currently present Test conditions have been completed 6059 Error: Wheel electronic undefined Error will cause a warning light Error is currently present Test conditions have been completed Pretty sure its the RDC unit. Gotta do more research. |
10-30-2013, 01:11 PM | #14 |
Rep 893
