01-16-2022, 06:13 PM | #1 |
Rep 205
08 E92 Oil Analysis Question - Source of Lead
Quick Question regarding my Blackstone Oil analysis:
Just bought an 08 6MT M3 ~106k miles and sent the oil off to get tested. Apparently I didn't send enough, and I'm not sure how reliable "spectral results" are however it's all I have as of now. Lead obviously tested very high. The 08 bearings are made out of copper, but from searching other posts, I've read there is a lead layer that wears before the copper. Just wanted to confirm this is correct, and that is the most probable cause of the high lead content. I'm replacing bearings regardless but wanted to be sure the most probable source of the lead. I also got a filter tested which had very large aluminum flakes. Is this most likely from pistons? Any help is appreciated. Last edited by Hein Jockins; 01-16-2022 at 07:22 PM.. |
01-16-2022, 07:15 PM | #2 |
Rep 2,997
High Lead content is exactly what you think it is. Rod bearings.
The lead layer is first to go, then you'll have the copper bearings exposed to the crank shortly after. Get the rod bearings done asap, with 74ppm of Lead it's not looking good.
INSTAGRAM: GORDON.M3
Hein Jockins92.50 |
01-16-2022, 07:20 PM | #3 |
Rep 205
Thank you-- just wanted to make sure my understanding is accurate, as this is my first S65. Bringing my car in this week to do RB's, so interested to see what they look like.
01-16-2022, 07:35 PM | #4 |
Crazy Frog
543
Rep 1,211
Show some pictures of the old rod bearings when you get em out.
01-16-2022, 08:38 PM | #5 |
Rep 205
I'll post em.
spammysammich1579.00 |
01-17-2022, 01:21 AM | #6 |
Rep 7,091
Wonder what the alu flakes are?
Post here once done: https://www.m3post.com/forums/showthread.php?t=1253084 |
01-17-2022, 06:00 AM | #7 | |
2008 BMW E92 M3
281
Rep 108
Drives: BMW M3
Garage List 2020 BMW 330i G20 [0.00]
2008 BMW E92 M3 [0.00] 1997 BMW M3 [0.00] 1978 BMW 325is [0.00] 1992 BMW 325is M Te ... [0.00] |
01-17-2022, 06:12 AM | #8 | |
Rep 7,091
Take a look down the oil fill, if its the covers that are loosing pain inside you'll see it. Edit: one of many examples: https://www.m3post.com/forums/showthread.php?t=935340 Last edited by Helmsman; 01-17-2022 at 06:38 AM.. |
Hein Jockins92.50 GORDON.M31415.50 |
01-17-2022, 07:24 AM | #9 |
Rep 205
Interesting. Didn't think of that. The most prevalent material in the filter was a non metallic paint or paint sealer. Could definitely be valve covers then.
01-17-2022, 02:30 PM | #10 | |
Rep 865
(This was one of the better looking rod side bearings out of my '08)
Chris, 2008 E92 |
01-17-2022, 07:29 PM | #11 |
Rep 205
Thank you! I knew they were copper bearings in pre lci, but this clears up where the lead is from. Thanks for the help. Pumped to actually drive this machine how it should be here soon.
Davisca4552207.50 |
01-18-2022, 12:57 AM | #12 | ||
E90 6MT MASTER
74
Rep 314
please share your results
01-18-2022, 11:43 PM | #15 |
Rep 205
01-19-2022, 04:08 AM | #16 | |
Rep 2,997
Lead/copper also in the 08.
