      02-17-2019, 03:45 AM   #1
E90_Dave
White E90 compack
E90_Dave's Avatar
Drives: White red Novillo leather E90
Engine malfunction-brake vacuum sensor or seal.
Car thrown into limp mode but goes away after i turn it off and restart it, but comes back after 10-15 lines of moderate driving. The engine sounds fine but the idle jumps right after the engine malfunction comes on. I hear this noise. I believe it's either the brake pressure sensor is bad or the brake booster seal is bad. I know the brake booster runs off vacuum so that could be it. Curious what you guys think. I hear the brake vacuum pump activate a lot more than normal, almost running all the time to be exactl.
      02-17-2019, 04:04 AM   #2
Redd
Sounds like brake vacuum sensor. Common problem.
      02-17-2019, 03:17 PM   #3
strokemycocktus
strokemycocktus's Avatar
Poland
66
Drives: E92 M3 6MT ZCP
Did you have any fault codes?
      02-17-2019, 06:38 PM   #4
Redd
I don't remember on mine, but internet says it should be P1209.
      02-17-2019, 10:45 PM   #5
E90_Dave
White E90 compack
E90_Dave's Avatar
I'm going to check the codes tomorrow it's Sunday and everywhere is closed. Fingers crossed it's only the brake vacuum sensor.
      02-19-2019, 01:58 AM   #6
E90_Dave
White E90 compack
E90_Dave's Avatar
These were the codes i replaces the brake vacuum sensor. Not sure if it cleared the issue only way to tell is to go on a drive.
      02-26-2019, 09:18 PM   #7
RevFreak
Drives: E93 M3 2011
Strange Iíve been dealing with this problem as well, got the brake booster and brake vacuum sensor replaced and the car runs fine. Only problem is every time I start the car no matter how long itís been off it needs to stay on for about 10 mins before I actually start driving if not boom engine malfunction. Any help?
      03-02-2019, 05:01 PM   #8
E90_Dave
White E90 compack
E90_Dave's Avatar
Originally Posted by RevFreak View Post
Strange I’ve been dealing with this problem as well, got the brake booster and brake vacuum sensor replaced and the car runs fine. Only problem is every time I start the car no matter how long it’s been off it needs to stay on for about 10 mins before I actually start driving if not boom engine malfunction. Any help?
Have you replaced the whole assembly or just the sensor ? I've heard of this issue coming up if the check valve in the brake vacuum sensor brake booster line going bad.
      03-02-2019, 06:42 PM   #9
serranot
serranot's Avatar
149
Drives: 2011 E90 M3 6MT
2011 BMW E90 M3  [5.00]
Throttle actuators . . .
      03-03-2019, 08:47 AM   #10
Mvy
Drives: 2008 E93 M3
Since you replaced brake vacuum sensors, perhaps fuel tank breather valve? Just a guess as that commonly causes idle flux.
Harrop Supercharger, BPM Tune, aFe stage two airbox, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive...
      03-04-2019, 11:18 AM   #11
E90_Dave
White E90 compack
E90_Dave's Avatar
Usually causes uneven idle randomly or after fill up but not really limp mode
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
