      02-16-2019, 04:28 PM   #1
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
ecs spacer issue
hello I order some spacers for the car m3 e92 15mm front 12mm for the rear but now the front end vibrate which didt have before the spacer they look well made good quality hub center and I did the install everything was done right have anyone had any issues with this spacer
      02-16-2019, 04:46 PM   #2
EnVe46
EnVe46's Avatar
650
Drives: 11 E90 M3
Installing spacers is surprisingly tricky. You have to place it in the hub and turn it until it does not wiggle. There's a sweet spot. Take the wheel off and wiggle the spacer where you have it now, it'll probably move a bit. Then spin it until it doesn't move at all.
2011.5 E90 M3 ZCP
Interlagos Blau
      02-16-2019, 04:51 PM   #3
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
I probably will try that and see if that fix the issue shifted perspective a YouTuber had to get his change do to vibration I was just wondering if anyone have the same issue with the ecs spacer
      02-16-2019, 04:54 PM   #4
sgreer78
sgreer78's Avatar
Drives: 2016 Cayman GT4
You're also adding leverage to the front, the extra force may be enough to feel an imbalance in your wheel/tire setup. If you can't sort it out with playing with the spacers, try that. I had issues with OEM ZCP wheels vibrating with spacers, aftermarket wheels were fine.
      02-16-2019, 04:56 PM   #5
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
I have oem 220 wheels I have to play with it I guess
      02-16-2019, 05:00 PM   #6
jazzy1999
Drives: E93
Keep us posted..I was a click away from purchasing the same set spacers from ECS. I have the stock OEM set up myself.
QUOTE=nekbreaker;24390984]hello I order some spacers for the car m3 e92 15mm front 12mm for the rear but now the front end vibrate which didt have before the spacer they look well made good quality hub center and I did the install everything was done right have anyone had any issues with this spacer[/QUOTE]
      02-16-2019, 05:05 PM   #7
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
[/QUOTE]
I will mess with it tomorrow and see if I can get that fix but ecs stand behind their product I already contacted them on the issue I will try the turnermotorsport brand and see what happens not before trying to get it right with this 15mm ecs set lol
      02-16-2019, 07:39 PM   #8
EnVe46
EnVe46's Avatar
650
Drives: 11 E90 M3
I've had 6 different sets of ECS spacers and until I figured out I needed to turn them to fit the hub, they vibrated. Also a set from h&r did the same
2011.5 E90 M3 ZCP
Interlagos Blau
      02-16-2019, 08:25 PM   #9
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: E90 M3 6MT
2008 BMW M3  [5.00]
use a wire brush to clean the hub and matting surfaces. then apply a light coat of anti seize and install the spacer. turn the spacer a few times on the hubs to set them. install the wheel and torque with minimal weight on the tire. ( let the jack down just enough so the tire touches the ground).
2008 E90, JB/FR
APEX / ECS / AFE / BORLA / Brembo / ESS / H&R / IND
Insta: @M_POWER_S65
      02-16-2019, 10:07 PM   #10
shimmy23
e90 daddymobile
shimmy23's Avatar
1032
Drives: e90 IB M3
Another spacer vibrates thread. Do people not know how to search google?
-brandon
e90 IB journal
      02-16-2019, 10:47 PM   #11
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
I did all that I will take them off tomorrow and check it again torque the wheel to specification
      02-16-2019, 10:49 PM   #12
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
another dude that dont like to help anyone just dont say anything if you didn't like it buddy that's what I do when I see a triple threat about something here
      02-16-2019, 10:55 PM   #13
shimmy23
e90 daddymobile
shimmy23's Avatar
1032
Drives: e90 IB M3
I've helped plenty.
It's just some of these issues are all over the web if you bothered to search.
-brandon
e90 IB journal
      02-16-2019, 10:58 PM   #14
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
I've helped plenty.
I like a response from someone that had the same issue that's all if that's a problem with you dont read the dam post I guess
      02-16-2019, 10:59 PM   #15
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
I've helped plenty.
not entertaining this comment from you have a great life dude thanks for nothing anyway lol
      02-17-2019, 02:33 PM   #16
shimmy23
e90 daddymobile
shimmy23's Avatar
1032
Drives: e90 IB M3
https://www.m3post.com/forums/google...er%20vibration
I've ran spacers from ECS, TMS, MS, H&R, and a no name brand. All have performed the same. The only time i've experienced vibrations was due to not properly torquing down the wheel evenly.
-brandon
e90 IB journal
      02-17-2019, 04:28 PM   #17
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
thanks for the info I will get the wheels balance and see if that's the issue but I took the front off and no vibration
      02-17-2019, 04:37 PM   #18
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
update I look again took the wheel off and check everything was fine torque the wheel to specs drove the car and vibration was still there took them off and they are on their way back to ecs they will send me the turner motorsports brand and see what happens
      02-17-2019, 06:57 PM   #19
Biginboca
Biginboca's Avatar
1055
Drives: 2009 E92 328i 6MT
Turner Motorsports spacers is what I have that caused an issue on my car. With my Apex Arc 8 wheels they caused a wobble on both sides. This is with lugs torqued with craftsman torque wrench:
I had to grind the spacers all around the center. They had a chamfer there that didn’t mate correctly with the inside of the wheels. This is what I did:
This is how the wheels run now:
      02-17-2019, 07:05 PM   #20
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
Originally Posted by Biginboca View Post
Turner Motorsports spacers is what I have that caused an issue on my car. With my Apex Arc 8 wheels they caused a vibration on both sides. This is with lugs torqued with craftsman torque wrench:
oh wow what did you used to grind that out just a regular grinder did you grind all 4 or just rears and thanks for that info
      02-17-2019, 07:08 PM   #21
Biginboca
Biginboca's Avatar
1055
I only run spacers on the rear. I used a regular angle grinder and just went around the spacer removing a little material. It’s likely only an issue with these spacers and these Apex wheels. Something about the fit of the spacers and these wheels, because I’ve run these spacers with VMR wheels without issues.
BTW, I installed this set up at Christmas and I had no idea it was doing this until 3 days ago. I was stopped at a red light and a guy rolled down his window to let me know my back tire was wobbling. I got out and looked all the lugs were tight and I felt nothing but I drove slowly and filmed with my cell phone out the window and sure enough could see the wobble when I watched the video. Never felt it at all and I’ve had the car over 120mph like that!
      02-17-2019, 07:27 PM   #22
nekbreaker
nekbreaker's Avatar
Drives: bmw e92 m3
I only run spacers on the rear. I used a regular angle grinder and just went around the spacer removing a little material. It's likely only an issue with these spacers and these Apex wheels. Something about the fit of the spacers and these wheels, because I've run these spacers with VMR wheels without issues.
BTW, I installed this set up at Christmas and I had no idea it was doing this until 3 days ago. I was stopped at a red light and a guy rolled down his window to let me know my back tire was wobbling. I got out and looked all the lugs were tight and I felt nothing but I drove slowly and filmed with my cell phone out the window and sure enough could see the wobble when I watched the video. Never felt it at all and I've had the car over 120mph like that!
I will check that out and see I'm running spacer on the rear with no issues but let's see when I get this turner spacers I really appreciate the info
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, vBulletin Solutions Inc.
