03-06-2010, 06:40 PM | #1 |
Rep 81
BMW Fuel Injector and Induction Cleaning service
Just had this done to my E92 with around 25k miles. BMW recommends the service every 2yrs or 20k miles. BMW charged me $250. At first I was skeptical as to the benefits...I've always put in 91 octane from the well known brands of gasoline and followed oil changes and service per the owner's manual. Was wondering if I would notice any benefits. Since I've never used Redline fuel injection cleaner between the oil changes and this thing is essentially a race car...I pulled the trigger.
We'll when I got my car back...it seemed that the responsiveness was improved and it ran smoother overall...similar to when it was new. Anyone else have the Fuel Injector and Induction Cleaning service done? Impression on results? Thanks, db |
03-06-2010, 07:36 PM | #2 | |
Rep 1,274
A subjective sensation of improved responsiveness is really not very reliable. |
03-06-2010, 08:04 PM | #3 |
Rep 81
Thanks for your opinion. Looking to hear back mostly from those who have actually had the service and can speak from their experience.
The BMW handout on the service actually states it can restore original performance and fuel efficiency. Do I believe everything I read...no. More of a skeptic on this type of stuff. But, some people swear by Redline and BK44. That's why I'm looking for first hand impressions from those who have had the service done. Last edited by dbacon; 03-07-2010 at 12:19 AM.. |
03-07-2010, 01:12 PM | #5 |
Rep 105
Drives: e90 M3 IB/FR
I pulled the injectors on my '88 M6 and had them cleaned and rebuilt by WitchHunter Performance. On that one, I definitely noticed a difference, as I was getting some hesitation on hard accelleration. They charged $19/injector. On a car with 25k, I'd be skeptical of the benefit, or need, to spend $250 on this service. I'd agree with TrackRat that an additive every so often will do as much or more as this service. Even with 115k on the M6, the pre-cleaning flow analysis said they were very clean...and I've been using LubroMoly Fuel Injector additive every few months. Just my $0.02
03-12-2010, 12:01 PM | #8 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
I think we are talking about two different things here.
There is no reason to pay for number 1. Rotate different brands of fuel and once or twice a year run one of the better cleaners through the tank. I recommend Red Line, Techron and Sea Foam. Number two is the actual cleaning of your intake. This makes a noticable difference in power and economy. Fuel system cleaners have no effect on this since they only clean the injectors and the area around the valve where the fuel spray hits. I used to remove the intake from my Taurus SHO once every year or two and clean it out with carb cleaner. The car always ran significantly better after each cleaning. The intake is gummed up by exhaust gas recirculation and PCV flow. Cleaning the manifold occasionally removes these deposits and causes the car to run much better. |
11-10-2010, 09:15 PM | #9 |
Rep 403
Drives: 20 G05 40i - Searching
Watch this video then decide if "proper" fuel injection cleaning isn't beneficial. BEFORE; you'll notice each injector sprays a different quantity of fuel. AFTER; not only are the spray amounts more equal, but they're spraying more fuel during the same 30 second time. This = increase performance and economy. Most dealers clean fuel injectors the same way you do. They put an additive in your fuel. Have your injectors tested and cleaned with an ultrasonic cleaning device. Cleaning solution is ultrasonically pulsed back (opposite direction than the injector normally sprays) up through the injector, dissolving and removing any carbon build-up on both the inside and outside of the injector. Just my 2 cents.
08 E92 335i - Pictured Below - Sold
07 E90 335i - European Delivery - Sold 01 E46 330i - Sold 91 E30 325iX - Stolen |
11-12-2010, 01:23 AM | #10 |
Rep 5,012
You don't need to use any of that if your car is properly tuned, and you always use a top-tier fuel with the additive already in it, like Chevron and others .
11-15-2010, 02:34 PM | #11 |
Commander-In-Chief
2121
Rep 8,922
Drives: 2023 M2 Coupe, 2020 GLE 450
I would agree with that for a newer car that has always used top tier premium fuel. Can't hurt to add a bottle of Techron every 3k as recommended, though.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
11-28-2010, 03:51 PM | #12 |
Rep 2,373
the issue with all the information you guys have posted is just because its a "top tier" fuel doesn't really mean the fuel your getting is good or bad...poor quality of fuel can come from anywhere-and you may not even really notice it. The simple fact of this is every engine creates carbon..poor fuel means more carbon typically and more buildup-ive seen the affects of these EFI services and they work-i at one point had bore scope photos of an engine before and after an EFI service and results surprised even me and im a huge skeptic of things like this...also-to comment on those who said you can dump in a bottle of techron in the tank-while this will help its the long time spent having the vehicle run solely on the cleaning solution that allows the carbon to be dissolved and burned-its far more potent than the in tank stuff.
11-29-2010, 10:36 PM | #13 |
Rep 321
11-30-2010, 09:48 PM | #14 |
Rep 9,032
Anyone try some Seafoam in the tank?
