02-10-2019, 11:46 AM | #1 |
Rep 38
Weight reduction please
Hello guys I need to take out the maximum weight that i can on the E92 for track What the part i can remove ? What the part i can replace by lightweight ? seats - DONE panel ? hood ? doors ? trunk ? exhaust ? wheels - DONE carbon roof - DONE Battery ? glass ? airbag remove floor remove wire lightweight ? ... other idea ? I know the maximum target possible is 1250kg, but this is very very complicated and very expensive .... thank for sharing opinions and informations |
02-10-2019, 12:08 PM | #2 | |
Rep 2,806
Drives: '09 E90 M3 - IB
So, let's start with, what is your actual goal? |
02-10-2019, 12:12 PM | #3 | |
Rep 38
My reality target is ..... under 1400 lol 1390 almost , 1350 as a small dream ! possible ? even if i have a roll cage ? |
02-10-2019, 01:55 PM | #4 |
Rep 12,726
https://www.bimmerpost.com/forums/sh....php?p=2509621
Battery, brakes, driveshaft, SPL titanium links, titanium bolts. Magnesium cage (you didn't mention a budget lol)
02-10-2019, 02:03 PM | #5 | |
Rep 38
yes i'm not rockfeller, sorry the budget is not unlimited lol |
02-10-2019, 02:53 PM | #6 | |
Rep 2,806
I think it could be relevant to what you want. 1400kg is around just under 3100 lbs. My car weighs 3250lbs/1474kg (no fuel no driver) with a full roll cage and full aero. HOWEVER, I have a supercharger that is almost 100 lbs, I do not have carbon doors---I have gutted OEM doors, and I have DCT (50lbs more than a 6-speed), and I have a sedan (which is around 50 lbs more than a 2-door). If you were to do a build similar to mine without a supercharger, put in carbon doors, and you have a coupe that's a 6-speed manual, I think it would get you to where you want to be. On that first post of my build thread, there is a full listing of what is on the car. And there's a bunch of pictures to show what it looks like. And my car is by NO MEANS as light as it could be. There are quite a lot of things that can be done to my car to continue making it lighter. But the truth is, the car is very fast as it is, so I haven't been in a hurry to spend the BIG $$$ to get much smaller weight gains. (I do want carbon doors though.) |
SYT_Shadow11479.50 |
02-10-2019, 10:19 PM | #7 |
Rep 8,076
Drives: 11 E90 M3 Individual
It's easier if you're willing to give up all luxuries like power windows. My E46 M3 sits at 2586lbs with no fuel and a full cage right now. I've pulled out about 1000 lbs so far with no structural CF parts.
2018 F30 320iX Melbourne Red
02-10-2019, 10:30 PM | #8 | |
Rep 6,734
'23 X7
02-11-2019, 12:29 AM | #9 | ||
Rep 6,218
Titanium bolts/screws/lugs/fancyshit don't belong on track cars lol
slicer2737.50 |
02-11-2019, 03:24 AM | #10 |
Enthusiast
117
Rep 150
Thanks for this! Are the original screws reusable on the SPL links? im installing these in a couple of weeks and if the ti screws will give headaches will not bother with them
02-11-2019, 04:24 AM | #11 | |
Rep 6,734
'23 X7
02-11-2019, 04:52 AM | #12 | |
Enthusiast
117
Rep 150
https://www.turnermotorsport.com/p-5...s-with-el-kit/ https://www.turnermotorsport.com/p-5...ecamber-links/ I was asking if I should use the provided screws in the kit or use oem screws.
02-11-2019, 05:32 AM | #13 | ||
Rep 6,734
'23 X7
02-11-2019, 09:03 AM | #14 | |
Rep 38
thank you, lets go to read your topic ! |
02-11-2019, 10:10 AM | #15 | |
Rep 12,726
are you running every part they make, or just a few?
02-11-2019, 10:31 AM | #16 |
Rep 6,734
I have the full package. Great parts; really well made with the exception of the Ti screws. Better than the other options I have seen and had (BW, Fall Line, etc). Plus they have given me fantastic tech support and custom length end links, hardware, etc to correct some clearance challenges I had with my eibach sway bars. I think it could be possible to make the Ti screws work with loctite but I have already stripped half of them. Plus I frequently find they loosen on their own. Stainless is more durable and can handle more tightening torque. This is one of the reasons that I'm not big on converting bolts to Ti in order to save weight. Weight savings is minimal and hassle is increased.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 02-11-2019 at 02:28 PM.. |
roastbeef11586.00 |
02-11-2019, 11:50 AM | #17 | |
Rep 12,726
