05-13-2017, 11:04 PM | #1 |
Rep 151
Single Turbo Build
Just wanted to make a quick thread on some progress on my single turbo build. Some1 on the fb group said I should post it on here....
05-13-2017, 11:08 PM | #2 |
Rep 333
Sweet! Just curious how you were going to route the exhaust from the turbo back?
11 E92 ZCP
02 Honda S2000 -741 whp 471 wtq (dynojet) @ 29.6 psi on e85; now on 34 psi, 800+ whp. |
05-13-2017, 11:30 PM | #5 |
Rep 979
Subscribed
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
///M-Night14.00 |
05-13-2017, 11:56 PM | #6 |
Rep 333
Lord no! I hope that was a joke. That'll look way too rice. I wouldn't even do that to my 1000 whp S2000. LOL
11 E92 ZCP
ZEEM3R144.00 |
05-14-2017, 12:01 AM | #7 |
Rep 151
kamber166.50 yidgyi235.50 Spoolin159.50 Ngilbe361618.50 Datsun280z12.50 Jpfabrications31.50 LuckiSevens227.00 |
05-14-2017, 12:59 AM | #8 |
Rep 11,891
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
05-14-2017, 09:30 AM | #10 |
Rep 151
Thanks well right now mid to upper 700whp...it will run a race gas blend with meth injection. Then I want to save and build the motor. Right now I'm going to upgrade the main bearings and rod bearings...
05-14-2017, 10:59 AM | #12 |
bOrN To DiE
413
Rep 1,738
05-14-2017, 11:41 AM | #13 |
Rep 10,610
The S65 motor is not much like the N54/N55. The S65 rods probably won't hold turbo torque for long.
Sean@PSI2132.50 commedeschatons134.00 |
05-14-2017, 11:50 AM | #14 |
Rep 151
05-14-2017, 02:30 PM | #15 |
Rep 1,122
05-14-2017, 02:32 PM | #16 |
Rep 1,122
Highly stressed, hi revving, all aluminum, high compression, thin walled s65 vs a motor that was built from the ground up from cast iron with thick walls for boost and heavy duty slow revving internals aka the German 2jz. Not really following.
shimmy232348.50 |
05-14-2017, 03:15 PM | #18 |
General
63226
Rep 24,651
The big question is for how long ?
05-14-2017, 09:08 PM | #19 |
Rep 330
I don't even think it will make it out of the dyno alive, s65 is nothing even close to the n54 engine that has forged internals, but hey what do I know... it's not like the S65 engine blows holes through the block bone stock anyway lol
///M Power-Belgium63225.50 |
05-14-2017, 10:01 PM | #20 |
Rep 151
05-15-2017, 06:40 AM | #21 |
Rep 10,610
Maybe use a boost controller to limit boost at mid rpm to keep the torque closer to 400 than 500 lbs rwtq while you build another engine. Or, instead of spending time to do main bearings now (a bunch more labor than rod bearings alone), pull the heads and drop in stronger rods and lower compression pistons as others have done for high power centrifugal builds. Not doing pistons and rods puts at risk the preventative maintenance of rod bearings and main bearings that you wrote you would be doing now. A rod through the block is a mess, disables the car, and makes you source another block.
05-15-2017, 08:56 AM | #22 | |
Rep 151
