      07-01-2019, 09:21 AM   #1
bmwpower603
Drives: E36 m3 coupe 08 e90 M3
Longer cranks.
Started my m3 today for the first time in a few days. And noticed it cranked for longer. And also heard a squeak/ crunch noise once it started.
I assume it’s probably ignition coils, since I just replaced the spark plugs. And maybe the belt tensioner / idler pulley causing squeak?
Sometimes while idling I’ll hear the motor making a clicking sound, then goes away, and then comes back again. Is this normal ? It sounds spark related for sure.
I’m already regretting not doing my ignition coils when I replaced the plugs!!
      07-01-2019, 11:02 AM   #2
pbonsalb
How is the groundstrap from the pan to rail on the drivers side? Give it a tug. Mine broke in 2.
      07-01-2019, 12:20 PM   #3
bmwpower603
which ground strap are you referring to?
It’s under the car from oil pan to frame rail?
      07-01-2019, 01:20 PM   #4
pbonsalb
Yes, worth a quick check. Caused a slow crank for me, especially on hot start.
      07-12-2019, 07:42 PM   #5
romero1990
Drives: E92 M3, F25 X3
2017 X3  [0.00]
2009 M3  [0.00]
I have the exact same issue. It always take longer to crank up after a whole night or long weekends. But hot start is fine. I got my battery replace, but still the same so far.
      07-15-2019, 07:20 PM   #6
BimmerMan33
BimmerMan33's Avatar
Drives: 2011 BMW M3, 2014 BMW X5
Fuel pressure regulator vs leaky fuel injector?
I have similar issue, longer cranks on cold start with intermittent hesitation, then does fine. No issues with hot start. Battery is 4 yrs old. I feel this is fuel related!
Pros... please comment!
      07-18-2019, 10:21 PM   #7
romero1990
2017 X3  [0.00]
2009 M3  [0.00]
come to think about it since you mentioned fuel. I think it mostly began around summer blend started.
      07-19-2019, 06:09 AM   #8
BimmerMan33
You might be on to something... but this issue didn't happen last summer!
Guess if it doesn't get worse, we'll wait for winter... it's never too far...Lol
      08-04-2019, 07:17 PM   #9
bmwpower603
Update* *
I finally got a fault code for prolonged cold starts. Not sure if it’s the cause.
But ISTA is telling me I have a faulty pressure sensor on the intake manifold.
I didn’t know this could cause longer starts. But I guess it does make sense.
