03-14-2020, 07:29 PM | #1 |
Rep 334
turbofans... anyone tried them to aid brake cooling?
i'd like to get the most of my stock setup before going bbk
after SS lines, SRF, pfc08, ducting, rotors (any suggestions for oem replacements that flow better?) has anyone tried turbofan wheel covers get more hot air away from the brakes? I know the look is polarizing but from a track usage point of view i think the functionality is there. |
03-14-2020, 07:44 PM | #2 |
Rep 12,726
the problem would be finding a wheel that fits properly on this platform. it won't be a cost effective solution. them money would be better spent on a proper bbk than wheels designed to cool the brakes.
the fastest guys on here have proper brakes and none run fanned wheels.
Bartledoo2691.50 |
03-14-2020, 07:51 PM | #3 | |
Rep 334
those would be significantly cheaper than bbk, i'm just not sure if the performance would be worthwhile. |
03-14-2020, 07:55 PM | #4 | |
Rep 12,726
all the examples i've ever seen had separate holes tapped into the wheel face that the "fan" is bolted to.
03-14-2020, 08:06 PM | #6 | |
Rep 1,591
03-14-2020, 08:11 PM | #7 |
Rep 12,726
add up the cost of all that stuff and you're probably not far off from an actual bbk, especially a more reasonably priced bbk like an st40 front and rear. then you could rotate pads. you'll have to do fluid anyways, and you'll have to buy pads anyways.
before you get nutty with a bunch of bandaids, add up the realistic costs and compare.
03-14-2020, 09:17 PM | #8 | |
Rep 1,591
03-14-2020, 11:46 PM | #9 | |
Rep 334
i have the SS lines and SRF here, but have not installed. the PFC/ducting/rotors were the next steps i was planning. what would you suggest? roastbeef thank you for the advice re: cost vs bbk, i definitely need to look into it more. i was looking at the brembo gt-s setup and that looks to be 7k+ for f/r. if you have any moderately priced bbk recommendations that will handle normal 20min hot lapping sessions at my home track WSIR, i'm all ears! |
03-15-2020, 12:28 AM | #10 | |
Rep 1,591
I run a similar brake setup on my race car and have had no issues with fade or performance, running R-comp and scrub slicks. I've stuck with stock rotors as I haven't needed the extra cooling capacity of the PFC or StopTech OEM upgraded rotors - also because I can replace them for free from FCP Euro. Before trying to get a turbofan wheel to work, which won't be easy, do what you listed above. It will likely be more than enough. |
03-15-2020, 12:34 AM | #11 |
Rep 12,726
there are a bunch of people happy with the stoptech st40 kits front and rear. a big benefit of a front and rear st40 kit is being able to rotate pads. bimmerworld has a 21% off and free shipping code right now. so you're looking at about $4,329 with stainless lines and some street pads. not terrible for the performance. this kit with srf and proper pads will do just fine at WSIR (one of my favorite tracks).
simply add up the costs of everything (no turbofans, i don't think you'll be able to achieve that reasonably) and compare the two. the st40 kit might be more reasonable. ducting is always good, but isn't always necessary. ducting also adds to cost and you'll have to figure out where to mount it, which is usually a front lip.
03-15-2020, 12:38 AM | #12 | |
Rep 2,806
Drives: '09 E90 M3 - IB
https://www.m3post.com/forums/showthread.php?t=1697076
03-15-2020, 01:48 AM | #13 |
Driver
2692
Rep 2,714
I went with stock brakes using PFC08 pads and SRF fluid my first season, but after a certain level I was getting pad fade and the pads just weren't lasting very long. I thought about ducting and upgraded rotors, but figured that in the long run I wouldn't be satisfied throwing money at bandaids (albeit in smaller increments). I'm happy I found a deal on a used bbk instead, although the initial purchase was quite expensive.
