10-10-2015, 11:40 PM | #1 |
997.1TT
1003
Rep 1,672
AK Motorsports Gallardo front calipers on M3?
https://www.akmotorsport.net/shop/bi...0-mm-oem-disc/
Anyone ever seen this setup? A local guy here has Gallardo calipers on the front and Porsche front Brembos on the rear of his E92 M3. I was always wondering where he got his setup, and I think I may have found where he got the front at least. For just under 1000 EUR, it seems like a great front setup. Question is, has anyone ever used these or seen them, and what are the options for a pre-fabricated Porsche setup on the rear (i.e. brackets already made). I know they have brackets for the E46, but never seen them for the E9x. The guy who has this setup tracks his car (a lot) and says the stopping power is phenomenal. For around $1200 for a front 8 piston Brembo setup? Sounds like a win to me. Before anyone starts talking about brake bias, and messing up the car by using braking components not designed for it, please refrain from posting unless you are going to state factual information you can back up with numbers and stats. I would like to keep this thread on topic.
Current: 2007 Porsche 911 Turbo Former: ESS Supercharged ///M3 Interlagos Blue ZCP Subscribe to YouTube: https://www.youtube.com/c/Rat3dM Follow me on Instagram: https://www.instagram.com/rat3d_m/ |
10-10-2015, 11:54 PM | #2 |
Rep 12,725
i don't dig it-
it says "specifically matched" but it was designed for another car. so it will fit, but was never intended for this application. with that in mind, you sort of have to assume they did the proper due diligence in researching brake torque, piston surface area, etc... i know you said not to post about this, but it is absolutely relevant. larger caliper on the oem rotor- no thanks. the rotor's ability to dissipate heat is just as important (maybe even more important) than the caliper. i think with the enlarged pad size (lets pretend it is double) is just going to put more heat into the rotors and overwhelm them sooner. these oem rotors can't get rid of the heat well enough to run that large of a pad. they are probably fine for the street, but if you plan on tracking them, i would speculate this is a very bad idea.
SYT_Shadow11479.50 |
10-10-2015, 11:55 PM | #3 |
Rep 62
I am really underwhelmed with stock brakes and feel this is a weak point for my M.
These seem like a great upgrade for overall street driving. Does anyone know how the brackets allow the caliper to be matched to original mount points? |
10-11-2015, 12:41 AM | #4 | |
997.1TT
1003
Rep 1,672
10-11-2015, 01:23 AM | #6 | |
Rep 12,725
even if the gallardo's rotors are the same size, the volume of the pistons and fluid capacity is most likely very different. this could change pedal feel and the way the brake mc pushes fluid. my initial though is also that if the larger calipers take more fluid and the rear calipers stay the same, you might be changing the brake bias not by stopping power, but by the path the brake fluid travels to the front/rear calipers. i know the oem rotors have a lower cooling vane count than bbk's, some have aluminum hats. not sure what oem is, but it is bulky and that likely contributes to them holding in heat. http://www.essexparts.com/shop/compl...m3-bundle.html there is more tech in that link than i care to type, but scroll down and it breaks down why their kit works so well. i know, i know, they are trying to sell you something. just read it and it will all make sense- these guys know what they are talking about. you can still take tech and discussion for what its worth where they break down the oem caliper/rotor and compare it to theirs. then compare it to just replacing a caliper not designed for our cars... i don't think you'll go for it. running a caliper that doubles pad contact on oem rotors then going to the track makes me cringe. lots more tech/discussion in this thread. http://www.m3post.com/forums/showthread.php?t=921567 i have since purchased this kit and it is top notch. again, whether you want this specific kit or not, you can get a good idea of things you (and I) probably don't think about when thinking of brakes. this kit is 5mm smaller in diameter than oem rotors, yet worlds above in terms of performance.
10-11-2015, 07:10 AM | #7 | |
Rep 10,614
10-11-2015, 07:54 AM | #8 | ||
Rep 12,725
10-11-2015, 12:41 PM | #9 |
Rep 1,318
I love those calipers, always wanted those coupled with this style rotor
http://www.ebay.com/itm/AUDI-LAMBORG...0056f7&vxp=mtr braking bias will only be affected if the rear is not upgraded, I would look into the piston sizes of the fronts and see how they compare to stock pistons as far as volume goes to avoid too much pedal travel the rotors that are used with these calipers are 365x34 where our calipers are 360x30 so I don't see how our rotors could be that much inferior to those and not do good with heat, that 4mm could be in the design difference and not the actual thickness of front and rear of rotor disk. For that money I think that's a steal as long as the rear could be upgraded accordingly |
10-11-2015, 05:23 PM | #11 |
IG: @dj_dub
1803
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
Thanks for sharing this! ...this interests me and would also love to see more information as well.
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
10-12-2015, 06:47 AM | #12 |
997.1TT
1003
Rep 1,672
I emailed the company asking if they had any options for rear setups, and asked if they would be interested in making a Porsche 996 bracket for the back. I quickly got a response saying they should have an option for the rear within a week, and they would send me info/pics when they have it. I am skeptical, because I doubt they are throwing something together just because I emailed them, and would expect more than a week of R&D/Fabricating to make a product, but who knows? Maybe they already had something in the works and I just happened to email them.
Either way, I would be interested in calculating the OEM brake bias, and then calculating the potential bias with these Gallarado calipers and Porsche 996 calipers on the rear, but I will need to do some more research on specs before I can do so, unless someone is bored and wants a homework assignment?
10-12-2015, 12:05 PM | #13 |
Rep 1,318
Good to know they are making a rear kit, I think any 4 piston rear caliper should do just fine/better then stock rear
I wonder if they are willing to sell just the caliper adapters front and rear? Also I think for the front if your worried about heat, you can always upgrade to ecs 2 piece front rotors later on. |
10-12-2015, 01:24 PM | #14 | |
997.1TT
1003
Rep 1,672
Alright guys, got an email from Akmotorsports today. Here is what it said..
Not sure what the rear calipers are from, but they are 4 piston Brembos similar to the Porsche calipers. So for €2195 plus shipping (about $2494) you can have an 8 piston / 4 piston Brembo setup. Sounds pretty good to me. If anyone is interested, I will find out about a Group Buy price. If this is real life, I am highly, highly interested in this. $2500 for a Brembo BBK seems unreal to me. Anyone care to be the guinea pig and place an order and let us know how it turns out? I'd love to see how these do on the track
10-12-2015, 02:45 PM | #15 |
Rep 1,318
Since your already in talks with the guy.
Ask what size pistons are in those rear calipers and ask if he would sell the caliper adapters by themselves? They look like Porsche 996 brembos, piston size would reveal front or rear. The rest of the stuff could be bought elsewhere there's still room for savings here. 2500$ is still a lot for junk calipers with new seals and some shiny paint. The adapters is the real worth here and if he will share part numbers of rear calipers. |
10-12-2015, 02:55 PM | #16 | |
Rep 747
10-12-2015, 03:17 PM | #17 |
Rep 1,326
sub'd for more info. i had a similar setup on my e46 m3 with porsche calipers and ZCP rotors. i'm hoping someone can do the math to calculate the brake bias with this setup
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
10-12-2015, 03:23 PM | #18 | |
997.1TT
1003
Rep 1,672
I agree, $2500.00 is still a lot for some rebuilt OEM calipers, but keep in mind, that includes everything. The 1000 euros on the website is for fronts, MINUS the pads. The 2100 euros in the email quote is including 6 sets of pads (4 for the front, 2 for the rear), calipers, mounting hardware, brackets, brake lines, i.e. everything needed for install, minus rotors if you chose to upgrade those as well. Considering it's a complete kit and a new aftermarket Brembo setup for our cars is upwards of $7000.00, this kit seems very reasonable. I would just question how well it will work (or won't, whatever the case may be) and I don't want to be the first to find out.
10-12-2015, 03:27 PM | #19 |
Rep 2,527
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
This sounds like "too good to be true"
10-12-2015, 03:48 PM | #20 |
IG: @dj_dub
1803
Rep 1,452
I hope it's not too good to be true...the price for a complete set makes me very interested.
10-12-2015, 03:56 PM | #21 |
Rep 1,535
10-13-2015, 01:00 PM | #22 | ||||
997.1TT
1003
Rep 1,672
I got an email from the company. This should answer a few questions:
Q. Will they sell the brackets separately? Quote:
Now that we know the specs of the rear calipers, anyone care to do some research to find out the specs for the fronts, and calculate brake bias? I searched, but couldn't find piston size for OEM Gallardo calipers.
