02-11-2009, 07:29 PM | #1 |
Rep 120
Smartphone cradle out yet?
I searched for 6NF and smartphone, but I didn't see any recent threads on the topic.
Has the iPhone cradle for the smartphone integration come out yet? I was under the impression that it was coming soon, but I haven't heard anything from my dealer since picking up my car in November. |
02-11-2009, 07:45 PM | #2 |
Rep 41
02-11-2009, 11:00 PM | #3 | |
Moderator
7515
Rep 19,368
OP, check the audio forum on E90post.com there is tons of info over there, including part numbers. However, the part is backorderd I believe. |
02-12-2009, 11:05 AM | #4 | |
Lurker
Rep 58
Drives: 09 AW E92 M3
I did some searching and found this:
BMW Adds Smartphone Integration (09 models, iPhone 3G) Then user bryanwxup reported the part numbers and had this to say: Quote:
Video of it in action. Here it is on BMW's accessory site. Hope this helps. I'm trying to locate one as well. |
02-12-2009, 11:21 AM | #5 |
Lurker
Rep 58
I'm a bit confused, however, because it seems lots of folks report the cradle does not allow music playback and is simply a way to charge the iPhone and extend its reception. Is it possible the 84 21 2 151 038 (without 6NF) cradle is just that: a charger and a connection to the car's antennae? If so, does the 84 21 2 151 043 cradle (with 6NF) add the ability to use the iPhone as an external music device (searchable, A-Z list, playlists, etc.)?
Can someone with an iPhone 3G, 6NF and the 84 21 2 151 043 cradle confirm that it 1) charges the iPhone, 2) extends the reception, and 3) allows for the iPhone to serve as an external music source? Thanks much! |
02-12-2009, 11:34 AM | #6 | |
Moderator / European Editor
1545
Rep 6,754
Best regards, south
02-12-2009, 12:53 PM | #7 |
Lurker
Rep 58
Thanks, south. You cleared things up perfectly.
02-14-2009, 12:29 PM | #9 |
Lurker
Rep 58
Talked to me CA. He ordered one for me but said it's on backorder (84 21 2 151 043).
02-16-2009, 05:20 PM | #10 | |
Rep 280
Great thread. Thanks...
'09 E92 ///M3 | Jerez Black/Black Leather | Sycamore Anthracite | MDCT | Premium/Tech/Cold Weather Packages | 19" | Moonroof | Enhanced Premium Sound |iPod/USB | Smartphone
'97 E36 M3 Sedan Hellrot Red/Black; '03 E46 330Ci Met. Gray/Black; '06 E46 330Ci ZPF Imola Red/Saddle |
02-16-2009, 05:28 PM | #11 |
Rep 280
Follow-up to previous:
If you have to order the cradle in addition to 6NF Smartphone Integration, what exactly is 6NF doing for you by itself?
02-16-2009, 06:31 PM | #12 | |
Rep 13,001
The platform is useless without the proper cradle. Before the 6NF, the iPhone was either connected to an OEM cradle for just charging and external antenna or to the OEM iPod adapter. Now, the OEM hardware -with its supporting software, of course- is able to combine both music access, control and playback and phone hard connections into one single platform. |
02-16-2009, 07:12 PM | #13 | |
Rep 842
02-17-2009, 06:52 AM | #14 |
Moderator
7515
Rep 19,368
If anyone finds out a part number for the 6NF eject box, please post here.
I realize that it is only designed for use in 6NF equipped cars, and comes installed in them from the factory. However, I'd like to get my hands on one anyway and see if there is an opportunity to patch in connections to a 6FL Y cable. This would allow non-6NF cars to play music from the cradle. |
02-17-2009, 01:07 PM | #15 |
Rep 280
Thank you, Technic. Wish my freaking CA had said something. I would have ordered it over a month ago!
02-19-2009, 07:48 PM | #16 | |
Rep 842
PM Me when you get in bro |
02-20-2009, 04:42 PM | #17 |
Lurker
Rep 58
Got a call from my dealership. They have the 3G cradle in (84 21 2 151 043). He says I need an eject button piece as well, which is ordering in addition to the cradle. The eject button is $143. Huh?!?! Do I need this? If I have 6FL and 6NF, plus the cradle, do I also need an eject button for another $143?
Thanks!
02-20-2009, 09:55 PM | #18 | |
Rep 842
Cradle cost $135 after tax and that took long enough. Had to order another one today that should be in on Tuesday. Little dealer secret to their ordering process from BMW I learned |
02-22-2009, 02:31 PM | #19 |
Rep 280
iPhone 3G/Smartphone Integration Update
Based upon all the posts above, and rising concern on my part, I went to the dealer yesterday to get some answers.
It's obvious that the dealers are trying to figure out the integration system as well, but my CA was very helpful. Yesterday, I went to the dealer with my iPhone 3G to figure this all out. They did not have a 3G cradle, but we sat in an '09 (335 actually) with smartphone integration. I plugged in the 3G through the Y-cord (6FL) and sync'ed the bluetooth. Well, the phone appeared to have FULL functionality. My contacts uploaded to the iDrive, I could call out and received calls through the car, flawlessly. I was even able to set one of the radio preset buttons to "one-touch" call my home phone. Worked fine. As far as music, that worked just fine, too. Shows under external device, showed all music, artists, playlists, etc. It charged and had a good signal as well. So, I'm wondering, while the cradle may look cleaner under the armrest, than hooking to the Y-cord, why is it a necessity? Comments appreciated, please! Want to get to the bottom of this ASAP. Not sure if I've simplified or complicated the matter...
02-22-2009, 02:40 PM | #20 | |
Rep 842
Other members have posted they have experienced no difference in reception quality, some have posted they have noticed a difference. I needed to find out for myself. |
02-22-2009, 10:02 PM | #21 | |
Lurker
Rep 58
If anyone knows differently, please chime in.
02-24-2009, 02:44 AM | #22 | |
Rep 636
Nope, you have it. The only extra feature is the increased reception when the phone is plugged into the cradle. $175 for extra reception. For about $5, you can buy a roll of duct tape and tape the phone outside to the roof for the better reception...he he. The cradle is a much cleaner installation for the phone. |
