09-30-2020, 09:39 PM | #1 |
Rep 16
Winter trickle charger
Yeah this won't apply to those who live South of the Mason Dixon line haha. What trickle charger do you guys use or does it even matter? My z06 has 1 that was built into the system since the battery is located in the back. I was looking at a few on Amazon 20-40 bucks, but wasn't sure if that was the best option. If this is the wrong forum I apologize!
09-30-2020, 10:23 PM | #3 |
Rep 151
Drives: 2013 M3: E92, ZCP, DCT
CTEK MXS 5.0, great charger/maintainer!
-Mike M.
2013 M3 [E92, Alpine White, ZCP, DCT] 2016 i3 REx [Tera World, Capparis White] |
10-01-2020, 08:04 AM | #4 |
F15 daddymobile
2352
Rep 3,512
Search button must be broken
10-01-2020, 09:32 AM | #5 |
1930
Rep 1,896
CTEK chargers are good, but specifically the "CTEK MUS 4.3 Polar" (the orange one) for cold weather use. The difference between the regular 4.3 and 4.3 Polar version is that for the latter, the plastic cords doesn't become firm and brittle as easily for below freezing temperatures.
At -10F or colder, the cords are going to feel stiff I wouldn't plan on moving them around such as bending them to fit in a corner. https://smartercharger.com/pages/ctek-mus-4-3-polar |
Davisca4552207.50 |
10-01-2020, 09:42 AM | #6 |
Rep 801
I prefer to disconnect the battery for storage.
Why? Because trickle chargers fail. I have personally had one fail and boil a battery over. (Fortunately not in car.) They also occasionally catch on fire. If you don't want to unplug the battery, I strongly recommend setting a reminder and just hooking up the trickle charger every few weeks rather than leaving it continuously connected.
10-02-2020, 07:54 AM | #9 | |
Rep 207
Are there any downsides to just unplugging the battery and leaving the trunk popped open? |
10-02-2020, 08:52 AM | #10 | |
Rep 16
Thanks for the suggestions! |
10-17-2020, 10:35 PM | #11 |
Rep 16
10-18-2020, 11:15 PM | #12 |
Rep 844
10-19-2020, 09:08 PM | #13 |
Rep 16
Yeah, I don't get it either. I saw enough posts online about it to figure it worked fine. I'm guessing Amazon just does that if something isn't specifically designed for a car, but I have no idea. This is what came up though when I clicked on it
10-22-2020, 11:19 AM | #14 |
Rep 141
I've been using NOCO for years for multiple vehicles, lead/acid, AGM, Lithium. It does em all.
NOCO Genius G750 6V/12V .75 Amp Battery Charger and Maintainer
-Kai
10-25-2020, 02:03 AM | #15 |
Rep 151
Crack.
-Mike M.
10-25-2020, 09:53 AM | #16 |
Rep 30
I've been using a Battery Tender Plus that I have quick connect leads on the engine bay charging terminals. It's a quick 10 second process to lift the hood, connect the lead to these quick connects and lower the hood again. Between a very short commute to work & now working from home for a long time, it's been a great setup.
Davisca4552207.50 scrammer421.50 |
10-25-2020, 10:26 AM | #17 |
Rep 979
I use the bmw branded ctek and it has been great , I still have the original battery in my car.
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
Davisca4552207.50 |
10-26-2020, 01:51 PM | #18 | |
Rep 141
You could setup a small SAE connector that you can connect at the windshield cowl so you don't have to open the hood each time.
-Kai
10-26-2020, 01:57 PM | #19 |
Rep 143
Can anyone who has mounted a charger connector under the hood, with a permanent install using eye connectors, please share pics of your setup?
2013 Fire Orange II E92 M3 ZCP
Bimmerworld (Quad) Resonated X-Pipe, AFe Stage 2 CF Intake, Carbon Project CF Plenum, Epic Motorsports Race Tune, Rogue Engineering Power Pulleys, Continental Extreme Contact Sport |
10-26-2020, 04:18 PM | #20 | |
Rep 865
Super easy install. I used short wire leads, so that when the zip tie breaks the connector still can't reach anything dangerous.
Chris, 2008 E92 |
10-26-2020, 05:41 PM | #21 |
Rep 143
Perfect, thanks!
Davisca4552207.50 |
10-26-2020, 11:30 PM | #22 |
Rep 4,341
CTEK also. I have a similar to this one. I have a 7 year old BMW battery in my 1M and still runs strong I just put it on the CTEK charger. I haven't had any other batter last more than 4 years in the last 20 years. Maybe a coincidence but better really impressed. BMW branded trickle chargers are generally CTEK too.
///M Power-Belgium63779.00 |
