01-18-2021, 11:38 AM | #1 |
Rep 412
Solved - Help Needed to Identify a BMW Part Number
I could use some help identifying the part number of this screw located where the felt belly pan connects to the aluminum under tray. For the life of me I can't find the part number online. The screw has M6 diameter threads and is approximately 18-20 mm long with an oversize washer on it. Thanks.
[IMG][/IMG]
01-18-2021, 01:42 PM | #2 |
Rep 360
it's a little hard to tell on realoem, so you might want to just check with the dealer, but is it 07119903995? Seems to be a M6 thread that's 20mm in length. The washer seems a bit smaller, but the picture you posted looking at the indents in the felt, is the washer currently on there too big? Maybe someone put the wrong bolts on there at some point?
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
InnerBlueSkies1092.50 |
01-18-2021, 01:59 PM | #3 |
Rep 950
Difficult find, Here is a definitive starting point?
https://www.realoem.com/bmw/enUS/sho...diagId=51_5860 |
01-18-2021, 02:12 PM | #4 | |
Rep 950
01-20-2021, 09:28 PM | #5 |
Rep 561
07147147513
01-21-2021, 08:30 AM | #6 |
Rep 412
Thanks to everyone who took a look for it.
Originally I wasn't able to find it on Real OEM, but finally came across it. In case someone else needs the part number in the future: 07147199289
