04-18-2023, 09:07 AM | #1 |
I'm in your face
65
Rep 451
WHEELS/TIRE EXPERT NEEDED: Can I run f8x m3/m4 wheels/tires on my e90M3?
I tried to do some research on my own, but couldn't find anyone with a similar setup. I found thee wheels locally, but from what I know it is made for the f8x m3/m4. Just curious if I can run this setup on my e90 m3. Any info would be appreciated. Thanks
Front: (2x) 19x9.5 +23 5x120 Rear: (2x) 19x11 +37 5x120 Tires are Michelin Pilot PS4 Front: 265/35/19 Rear: 295/30/19
Follow me on Instagram: M4rylandf82
exterior: Enlaes front lip, Mode Carbon r1 rear diffuser, M performance trunk lip, M performance mirror caps performance:AWE non-resonated exhaust 90mm diamond black tips, Swift Springs Wheels:Volk TE37SL Mag Blue 18x9.5/18x11 |
04-18-2023, 12:58 PM | #2 |
Rep 5,516
The rims will physically fit, but you may need to have some negative camber up front or not run the car lowered.
The tires sizes are too big (too tall) front and rear, you will need to change tire sizes. i.e. front 265/35 19 needs to be 265 or 275/30 19
Auto Detailing Enthusiast!
04-18-2023, 02:17 PM | #3 |
Rep 1,855
i ran the 437Ms on my E92 for a while. 12mm spacer upfront and 7mm spacer rear
265/30/19 and 305/30/19
04-19-2023, 09:22 AM | #5 | |
Dont listen to me
908
Rep 648
The only thing that is "wrong" with that setup is the 265/35 front tire is too tall. To not rub, you need a maximum front tire diameter of 26" or a 265/30 tire. For the rear, you could run a 7.5 or 10mm spacer to flush the rear wheel/tire out to the fender better. |
