      02-22-2019, 05:44 PM   #1
M3jamaica
Drives: 2008 e92 m3
Newbe Camber alignment HELP!!!!!
So I went to get alignment, they telling me Camber cannot be adjusted, left side is at -3, right at -0.6. That don't feel right to me. I have a 2008 competition package. All stock. Can I get it properly adjusted?
      02-22-2019, 05:47 PM   #2
M3jamaica
Drives: 2008 e92 m3
And if it cannot be adjusted, why such a difference? Problem with rack end? Shocks? Sorry, I'm in panic mode
      02-23-2019, 03:55 AM   #3
dpaul
Drives: 2009 E90 335xi, 2011 E93 M3
I don't know if the competition package might be different but normally there is a locating pin that prevents camber adjustment. It can be pretty easily removed to allow a small amount of adjustment but only 0.5 or so.
-3 is greater than expected in a stock vehicle, too much for the street and possibly too much for anything. Further, as you state, the difference between the sides is very abnormal.
I wonder if the shop is accurately measuring things. If they are, I'd guess something in your chassis/suspension/wheel is seriously bent.
      02-23-2019, 06:48 AM   #4
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
Your lower control arms are bent. Replace them, and the tension arms and go back for the alignment. If it's still out of wack, go to a different alignment shop. it's hard to believe the issue is anything more than that.
2014 M5 6MT
      02-23-2019, 08:11 AM   #5
M3jamaica
Drives: 2008 e92 m3
Thanks. Will do. I did drop in a huge pothole last week, it tear the tire and buss up the strut, most likely something bent.......
      02-23-2019, 08:51 AM   #6
Solo_M_Tech
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
See, there you go. You knew the answer to your question all along.
2014 M5 6MT
      02-23-2019, 12:11 PM   #7
macdude357
macdude357's Avatar
467
Drives: IB E90 M3
Just an FYI, Competition Package didn't start until 2011 so there are no 2008 Competition Package cars. I hope whomever you bought it from didn't throw on Comp Pack wheels and try and pass it off as a Comp Pack car.
      02-23-2019, 07:09 PM   #8
M3jamaica
Drives: 2008 e92 m3
Didn't know that. It has the wheels, springs, EDC, everything a competition package has....well good to know still....
